  1. imported_Tariq
    imported_Tariq Guest
    Hi i plugged my car into Vagcom and its come up with:
    17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
    P1290 - 35-00 - -
    17524 - Oxygen (Lambda) Sensor Heating: B1 S1: Open Circuit
    P1116 - 35-00 - -
    Any ideas?
    T
  2. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    Do you have a black or green top temperature sensor?
    Located to the right of the engine.
    If you have the black top, replace it for the green top version.
    A faulty or black top version can cause a loss in power/boost.
  3. peteA3tdi
    peteA3tdi Member
    408
    what car and engine size is it?
    clear the codes test drive and see if they come back
  4. imported_Tariq
    Hi i finally got round to replacing the sensor however still no joy eve though i replaced it with the green one. My lamba sensor is also not giving any readings....
