Any ideas? TQS idle and running issues!
Martynh Jul 7, 2012
  1. Martynh
    Martynh New Member
    14
    Hi all
    I have an intermittent problem with the TQS which I am hoping someone may have a suggestion of where to go next with!
    Basically, the revs will suddenly drop when idling and then hunt without cutting out,seems worse when there is a high ambient temperature or been sitting in traffic. Also when the car is having an 'episode' when you try to pull away it struggles and you have to rev it over 2.5k to pull away or it stutters, also it is well down on power and you can hear the turbo spooling but not reaching full boost.
    It will then go back to normal again and drive like nothing is wrong!
    I took it to a Audi specialist who plugged it in, only 2 faults logged, an intermittent over boost and an intermittent n80 problem. The chap chap ran a test on the solanoids and all worked fine. No obviously boost leaks or split pipes
    Ive now replaced the n80, cts and cleaned out and reset the throttle body
    Anything else I could try, I'm running out of ideas now and it's driving me slightly nuts!!
  2. Sulli79
    Sulli79 Active Member
    541
    37
    Mine did something similar, replaced the Lambda sensor and cleaned out the MAF, seems ok now.
  3. Martynh
    Martynh New Member
    14
    Thanks Sulli, was yours throwing any fault codes for the lambda or maf?
  4. murran
    murran Well-Known Member
    1,545
    39
    pcv issue? when its struggling to tickover, can you remove the oil cap/dipstick does it cut out straight away?
  5. Bradderz_1988
    3,958
    238
    Mine had a faulty MAF revs would drop to say 600rpm then car would rev to about 1800rpm, i disconnected the MAF whilst it was doing this and it went straight away gave it a drive with it unplugged and it was alot better at low revs, swapped the MAF and all was good !!!
  6. Martynh
    Martynh New Member
    14
    Thanks guys will give the maf trick a try next time it is playing up
    Dont think it's PCV as I can open the dipstick/ oil cap no problem
  7. Sulli79
    541
    37
    No codes showing up, just really poor mpg and idle revs all over the place. All seems ok now, but will be changing the fuel filter and getting a spare set of injectors cleaned and fitted too.
