Any ideas on these fault codes?
timontour Nov 3, 2012
  1. timontour
    timontour Member
    37
    Hi i just scanned my car and it came back with these codes any idea what they are?
    also i tried to scan for a fault on my rear parking sensors but it always says control module not found? could the module be faulty?
    or am i scanning the wrong module?
    VCDS Version: Release 11.11.4
    Data version: 20120807
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 56 62 72
    VIN: WAUZZZ8P27A214962 Mileage: 137010km/85134miles
    01-Engine -- Status: Sporadic communication error 1000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 8P0 907 115 K HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0040
    Revision: 5BH16--- Serial number: AUX7Z0G3FNP0AJ
    Coding: 01030003180F0060
    Shop #: WSC 00024 000 00000
    VCID: 3A55EE9E758A8FC82F1
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
    Component: ESP 4MOTION MK60 0102
    Revision: 00H13001
    Coding: 0021122
    Shop #: WSC 06314 000 00000
    VCID: 72C506BE6D7A3788271
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AC HW: 8P0 820 043 AC
    Component: KlimavollautomatH19 0360
    Revision: 130321 Serial number: 8P0820043AC
    Shop #: WSC 00000 000 00000
    VCID: 6DFF15C27444E870FA3
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H43 1201
    Revision: 00H43000 Serial number: 00000007023621
    Coding: E18C5F01B014100000160000160000000008FE175C0100
    Shop #: WSC 06314 000 08192
    VCID: 40A19C761356D518615
    Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0090
    Coding: 00150573
    Shop #: WSC 06314
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 136486 km
    Time Indication: 0
    Date: 2012.09.29
    Time: 11:39:00
    Freeze Frame:
    ON
    Voltage: 12.30 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H13 4260
    Revision: 91H13426 Serial number: 003620G45A47
    Coding: 0071612
    VCID: 42A5967E1D5AC708771
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0002012
    VCID: 41A79972185CDC106EB
    Part No: XXXXXXXXXXX
    Component: E0221 H07 0090
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 G HW: 8P0 920 981 G
    Component: KOMBIINSTR. VDO H20 0570
    Revision: D0H20004 Serial number: 2243G004006358
    Coding: 0005418
    Shop #: WSC 00581 210 64475
    VCID: 3C59E8867FBEB1F83DD
    Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H12 0170
    Revision: H12 Serial number: 330010741301B6
    Coding: BD3F034207002103
    VCID: 2F43CFCABEC85A6088F
    1 Fault Found:
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 136486 km
    Time Indication: 0
    Date: 2012.09.29
    Time: 11:40:00
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 L
    Component: Haldex 4Motion 0116
    Coding: 0000001
    VCID: 364DFAAE41926BA8CB9
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H20004 Serial number: AUX7Z0G3FNP0AJ
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000688
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.079 H07 1806
    Shop #: WSC 02069 000 90108
    VCID: 354FFDA25C9460B0C23
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 F
    Component: KSG H08 0070
    Coding: 9980202002186D098505489FC637
    VCID: 3FA39F8A6EA8AAE018F
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH04 0180
    Revision: 00003 Serial number: 30674702867448
    VCID: F1C789B2E87C8C905EB
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000688
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 186 S HW: 8P0 035 186 S
    Component: R Concert2+ H03 0280
    Revision: 00H03000 Serial number: AUZ1Z3K6048403
    Coding: 0000000
    1 Fault Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 5
    Fault Frequency: 1
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 D
    Component: Tuer-SG 020 0070
    Coding: 0000144
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 D
    Coding: 0000144
    End ---------------------------------------------------------------------
  2. fossie
    fossie Member
    207
    If you go onto the Rosstech website i beleive they have the codes listed buddy
  3. hades-
    9,481
    646
    01314 - Engine Control Module 01314 - Engine Control Module: No Communications
    Possible Causes
    • CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
    • Fault(s) stored in Engine Control Module
    • Engine Control Module recently flashed or re-mapped
    Possible Solutions
    • Check CAN-Databus Wiring/Connectors from/to Engine Control Module
    • Check Measuring Value Blocks (MVB)
      • Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
    01314 - Engine Control Module: Check DTC Memory
    Possible Causes
    Possible Solutions
    • Check Engine Control Module for Fault Codes
    Special Notes
    • Engine Control Module stored a Code which influences other Control Modules Functionality.
    • To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
    [TABLE="class: gumax-row"]
    [TR]
    [TD="class: gumax-row-right"]
    Possible Symptoms
    • Malfunction Indicator Light (MIL) active
    Possible Causes
    • Control Module not coded
    Possible Solutions
    • Check Control Module Coding
      • Cross Reference Control Module Coding with related Control Modules (e.g. for Country or Powertrain Settings)
    Special Notes
    Retrieved from "01042 - Ross-Tech Wiki"
    Category:
    [/TD]
    [TD="class: gumax-row-left"]
    Categories
    Meta
    [​IMG][/TD]
    [/TR]
    [/TABLE]
  4. timontour
    timontour Member
    37
    thanks for the replies!
    this would make sense as the car was mapped a few weeks ago, but it had no fault codes after the map?
