Any Good VAG-COM Information for B6 A4?
Haroulli Dec 21, 2006
  1. Haroulli
    Haroulli Member
    31
    Ive used VAG-COM before on my old MkIV GTi but i guess different cars are different.
    Ideally i want to get my fog lights to run with my little side lights. This is the information Ross-Tech gives me:
    However, it does not say where i'm to go to edit it, in VAG-COM's software, I open up 09-Elec. Ctrl. Mod. but then what? Do i need to find the channel? Or do i do a Recode? etc etc.
    Anymore handy options will be much appriciated.
  2. Sebastian
    Sebastian Member
    286
    Since it says "coding", it should be obvious that this means function 07, which is also called "coding". :)
  3. sjokolademelka
    sjokolademelka Member
    37
    Now that was rude, Sebastian :p
  4. Sebastian
    Sebastian Member
    286
  5. sjokolademelka
    37
    I was merely joking :D
    Sorry for the OT Haroulli..
  6. Haroulli
    Haroulli Member
    31
    Sebastian on my version of VAG-COM its "Recoding"
    Anyways i figured it out
    for my original thinking, i wanted to set my foglights to work with the side lights.
    My software code was set to 0003 so i set it to 0001 to set from USA to Rest of World however it hasn't worked! Still as before!
    Ideas?
  7. Uwe@Ross-Tech
    Uwe@Ross-Tech Member
    130
    Perhaps you should consider updating to the current version rather than using an ancient one which which is no longer supported. :banghead:
    -Uwe-
