Any advice on doing suspension?
Cviji Jan 16, 2011
  1. Cviji
    Cviji Member
    58
    I apoligise if this topic has been done to death, but ive done a good search and cant find much on actually fitting of springs/shocks.
    Planning on putting a set of sport shocks and Koni springs on my B6 next weekend. Just wondering, does anyone whos changed theirs themselves got any tips? I did the same when I had my B5 a couple of years ago.. Had a quick look around with the wheel off and the setup looks fairly similar?
    Also, whats the deal with wheel alignment? Are most garages able to correct this?
    Any help would be greatly appreciated.
  2. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Use this company, just type in your post code for your nearest Hunter Wheel Alignment center.
    www.AlignMyCar.co.uk
  3. Dsport
    Dsport Active Member
    243
    70
    I would go this way and you dont have to undo the painfull double balljoint link
    FRONT;
    (obviously removed wheel first)
    Undo antiroll bar link (16mm)
    Undo and remove bottom strut nut and bolt (18mm) and move the shocker over the wishbone
    Now from under the bonnet undo the 3 16mm bolts holding the the top cup in place.
    Now spin the hole strut round and undo the 16mm nut and bolt from the wishbone (cup end) then spin it round a but more and undo the other 16mm nut and bolt and there you have your strut.See pics
    Once you have changed the spring and shocker over build bac up in reverse order
    REAR:
    I took off the rear caliper so I didnt stretch the flexi
    Undo Rear shocker at the bottom (22mm)
    Undo rear anti rollbar link 16mm
    On the top link the is an 18mm nut and bolt BEFORE undoing this Mark as its offset bolt for the cast/camber. Then remove
    I still had to bar down the rear arm a little to get the spring out
    rebuild in reverse order and make sure you line the camber nut back up
    Hope this helps
  4. Cviji
    Cviji Member
    58
    That does help, many thanks mate :thumbsup:
  5. Cviji
    Cviji Member
    58
    Aah, I was struggling to get to the top arm bolts due to lack of a second flat 16mm spanner, So I decided to take on the double ball joint nut and bolt and it bloody snapped! brilliant...
  6. CMD
    3,015
    17
    Unlucky DIY is a pain sometimes :(
  7. PaulTheo
    PaulTheo Member
    126
    I hope the bolt comes out I have had to drill a few out. You need to be very careful and accurate if you need to drill it out. I take the lot out and do it in my drill press but getting it set up right is a pig of a job.
