Anti roll bars which ones?
sp84 Dec 8, 2010
  1. sp84
    sp84 Member
    Hiya I need new front and rear anti roll bars for my 2000 s3 and I wanted to no which ones are the best 1s to go for. The car has been lowered 60/40 thanks.
  2. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
  3. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,267
    360
    ive got Neuspeed, 22mm up front and 19mm at the back, it has significantly reduced the understeer
  4. mk1chopper
    mk1chopper Missing the S3
    1,092
    12
    Whats your budget like? The R32 arb's are a very good cheaper alternative to the neuspeed setup.
  5. sp84
    sp84 Member
    Budget is around £200 to £300 for both roll bars
  6. jojo
    28,907
    3,563
    this along with the Bilsteins and H&R springs handles very nicely indeedy.
  7. sp84
    sp84 Member
    I've got ap racing shocks and springs
  8. Alex C
    3,267
    360
    indeedy it does
  9. DPM
    DPM Site Sponsor Site Sponsor
    5,023
    206
  10. IOM-S3
    IOM-S3 Member
    119
    i have bought a 23 mm r32 roll bar with some standard bushes, getting the rear one also to go with my bilsteins and H&Rs, hopefully it will get rid of the horrible understeer
  11. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    i have eibach ones and i love em. i have an A3 though
  12. IGI
    IGI Member
    85
    R32 arbs :) on my S3 ....cheap mod. Eibachs may be too stiff
  13. DPM
    5,023
    206
    Personally I don't think the R32 bars make enough difference.
    Damian @ DPM Performance
    Mrharris2 likes this.
  14. danger S3
    danger S3 Member
    372
    sorry to be stupid but what's wrong with the oem ones?
    what benefit do you get from upgrading?
  15. Speedy Steve
    Speedy Steve Active Member
    1,258
    I have the H&R set on mine and love it!
  16. Dane
    4,086
    182
    You mean you did, the remnants are all over the front of Bills place neatly arranged around the speed bump. :laugh:
  17. Speedy Steve
    1,258
    haha no that wasnt the ARB's just the bumper and sump
  18. jojo
    28,907
    3,563
    OEM ones out the box are a bit soft, upgraded ones are generally bigger, so stiffer, making the car corner more flatley.
  19. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    What's the circa price for fitting front and rear ARBs guys?
  20. superkarl
    superkarl MAN OF STEEL
    9,494
    2,436
    and, how difficult to do it yourself?
  21. Speedy Steve
    1,258
    Front one was a bit of a nightmare had to drop the subframe rear was a breeze did it in half a day though on the road
  22. fingermouse
    fingermouse thats me
    4,003
    112
    I fitted The R32 arb`s , rear first then front a few months later and they make a hell of a difference over the std ARB. The rear is the most noticable.
  23. Dani_B19
    9,320
    389
    19mm front and 16mm rear, i like tobe different :).
  24. DaveA3
    2,370
    15
    back will take 5 mins. front will take about an hour
  25. thegoal007
    thegoal007 Another S3 owner....
    805
    26
    So....it will compromise the overall quality ? A step worse than putting 18" instead of the standard 17!
  26. The Stig
    The Stig Member
    33
    What are the best ARB's for a S3 on oem suspenstion?
  27. jojo
    28,907
    3,563
    Are you talking about ride quality here? ARBs don't effect ride quality as such when going in a straight line, they simply reduce body roll when leaning into corners, but you need half decent/uprated shock absorbers to make the most of bigger ones, as they are obviously stiffer and give more work for your suspension to do, should you hit some bumps mid corner.
  28. BuuBBa
    BuuBBa Member
    133
    Will the ARB's from Mk4 golf TDI 4motion (6spd) fit to S3?
    Found out that those have same diameter than R32 bars (23/19mm).
  29. scotty_24
    scotty_24 Well-Known Member
    1,050
    249
    I have the eibach bars on my s3, difference is amazing!
  30. Logic_Dan87
    Logic_Dan87 Member
    46
    anyone eles got eibach bars on there s3 ?, how would you rate them.. ?
  31. Gops
    3,198
    666
    Neuspeeds with billies and h&r's here! Handles wicked!
  32. Jimgrim77
    Jimgrim77 Member
    957
    20
    H&R roll bars here. Massive difference over standard.
  33. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Think you'd better re-check because I'm sure the rear (if not front aswell) is the same as the S3 bars.
  34. chazza55
    chazza55 got an S3 8L: living the dream
    173
    i notice everyone talking about using H&R springs with the billys........when i was researching everyone was saying eibach prok kit springs were best..............can anyone comment?
    I used the eibachs and to be brutally honest they seem softer than oem. i know they are meant to be progressive but i feel like i am in a jelly car sometimes!................does this sound like other people's experience at all?
    are the eibach better / worse than H&R for the springs?
    (s3 btw).
  35. S3Zek
    S3Zek Member
    410
    which out or the two do you think gives the best balance to an s3, H&R 25mm/21mm or Eibach 26mm/24mm
  36. Jimgrim77
    Jimgrim77 Member
    957
    20
    Both will improve current set up.
    Not many, if anyone, will have tried both on their actual cars and few will have experienced both of your choices on other vehicles under the stresses of, shall we say, enthusiastic driving which is where you'd really notice real body roll and the benefits of either.
    Essentially, I was in a similar situation and I wanted to just correct the understeer as best i could and taking the advice from various forums and agencies, felt that the H&R's gave the car the best balance. On the car, they feel great and I don't regret them...and that's my point as both of your options will be a great improvement and whichever you choose is likely to be something you will be recommended soon. It's a case of you say tomatoes...i say tomatoes.
    Hope this helps
