Anti roll bar links
Cviji Sep 30, 2007
  1. Cviji
    Cviji Member
    58
    My anti roll bar link are on there way out, knocks along over the bumps. Can these be done without a ramp or does the car need to be on its wheels for them to be changed? would mean I could do it if they didnt. Any help appreciated.
    Thanks.
  2. mwarrey
    mwarrey Member
    280
    You can change them with the car jacked up, it just needs to be level so as long as you use axle stands you should be ok. The links have been changed to a new design so make sure you get the new type.
    Are you sure its the antiroll bar links though ? I changed mine, but later found it it was a lower bent arm that was causing the noise.
  3. Beef
    Beef Member
    74
    Ask for the new bolt kit to go with them - should cost you an extra £2...it will all make sense when you come to fit.
    You may find after doing this that there's still a knock, in which case check the front lower arms...they love to knock.
    Cheers,
    Beef
  4. billybravo
    billybravo Active Member
    1,045
    ive just done all my arms for around 120 and she drive so smooth now :)
  5. bredhurststeve
    bredhurststeve Active Member
    136
    27
    just had my upper arm done and a rear wheel bearing and the car feels so much more solid when going round bends now
  6. scrupes
    scrupes bloody great extension bodger
    236
    Dont talk to me about knocks and bangs or creaks and squeeks!
    I'm ****** sick of it, i have changed EVERY link arm, balljoint, bearing, "c" link, shockers and springs, hub carriers, track rod ends, anti rollbar bushes, strut top mountings and i still cant find the source of the noise!!!!
    seriously this has cost me the best part of £2000 this year. all that's left is the steering rack (£400 quote) and engine mounts/ subframe mounts (£235 quote). i even bought new tyres even tho the oldies had 3.5 - 4 mm left.
    any further ideas ????
