Antenna amplifier location
A3 Driver Sep 6, 2013
  1. A3 Driver
    A3 Driver New Member
    Please can anyone tell me exactly where the antenna aerial amplifier is located within the car (A3, 2002 reg, post face lift, 1.8)?
    I'm pretty sure it's part # 4D0035530C.
    My radio signal has gone completely and I'm going to try to replace this part to get the signal back...
  2. mattyboy199
    mattyboy199 Well-Known Member
    1,889
    29
    If its not built into the based on the roof (which is where it comes from factory) it will be located under the base inside the car (this was a newer design)
  3. A3 Driver
  4. A3 Driver
    Thanks Matty,
    Just to check I understand right...you're saying that it should either be in the roof or under the bass box in the boot?
    I've had some trim off the roof around the aerial today and couldn't see it - where exactly in the roof should it be?
    cheers
  5. mattyboy199
    1,889
    29
    No the base of the aerial (cone shaped) on the roof (externally) is the amplifier it will be solid. If not then the amplifier will located inside the roof beneath the base. If you have rear interior lights pull the unit out & have look.
  6. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    the FM boosters are in the trim around the inside of the rear screen as they use the heated rear screen element to get more signal
  7. russwuss
    russwuss Active Member
    549
    106
    43
    Have you recently changed the stereo? Some built in Audi stereos have a amplifier, if you have a aftermarket one it won't have this amplifier.
  8. A3 Driver
    A quick update...
    It's a bee-sting screw-in aerial base - so the amplifier isn't externally within the base
    I've had the internal rear passenger light out and it's not internally beneath the aerial base
    I've pulled down the plastic trim that surrounds the top of the rear window internally - not there either.
    The only trim parts I haven't taken off are the plastic trims to the left and right of the rear window, that also go towards the rear passenger doors...
    It's a factory standard audi chorus radio/cassette...no AM signal at all, FM signal only in high signal strength areas - then it crackles into nothing as I drive away from the area...
    Thanks for all your advice so far...keep it coming!
  9. taffjohn
    taffjohn New Member
    27
    Hi Mate,
    I have the same problem, if you find out how to replace, could you let me know.
    I've been searching internet looking for a video of how to replace aerial base, but so far no joy!
  10. A3 Driver
    ...Audi just quoted £91 + VAT an hour to diagnose the problem. They said if it didn't take an hour, £ would be deducted according to how long it did take. They'd then provide a full quote for what needs to be done and how much it would be to fix. hmmm...Probably looking at around £250 maybe for Audi to fix...
