answer for me these questions 3 (Tractor noise when starts and vcds error)
danger S3 Oct 7, 2010
  1. danger S3
    danger S3 Member
    362
    evenin guys and gals, i hope were all well and your cars aren't miss behaving too much
    my car has been on long life service for 100k miles and since i got the car a few months ago ive cleaned out the sump, pickup and cam cover so im a bit happier now that it isnt getting starved of oil anymore.
    is there a way in vcds to check the oil pressure? and if so what should it read?
    the tractor noise when it starts only lasts about a second and as far as I'm aware was caused by the engine getting starved of oil a bit. but what I'm wondering is what is it that's actually making the tractor noise? a particular bearing? and is it fixable?
    finally i did a vcds scan today and it came up with a fault i had previously which is
    Address 01: Engine Labels: None
    Part No: 8N0 906 018 J
    Component: 1.8L R4/5VT 0004
    Coding: 10710
    Shop #: WSC 01236
    VCID: 387B57F83221
    WAUZZZ8LZ11001100 AUZ7Z0A1825243
    1 Fault Found:
    17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
    P1296 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    i changed the temp sensor (059 919 501A - the green one) and cleared the codes after. i'm guessing it will be the thermostat which i can imagine is a nightmare to replace
    any ideas?
    cheers
  2. Broken Byzan
    13,237
    465
    What engine code do you have?
    Its more likely the cam chain tensioner rattling as it too is hydraulicly controlled.
    Some models also have electiral control and this makes them uber expensive to replace
  3. danger S3
    danger S3 Member
    362
    my engine is an AMK
    i hope its the cheaper version ;-)
  4. finesse
    finesse Active Member
    2,805
  5. coopsS3
    coopsS3 Woosh Woosh Wah...
    30
    Chain tensioner = tractor= £420incl vat 
  6. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Yep, AMK engines are VVT engines, which means expensive tensioner.... Sorry :(
  7. danger S3
    danger S3 Member
    362
    thanks for the info guys. can't believe there so expensive. stupid awesome shiny black money pit :eyebrows:
    how serious is the chain tensioner tractor noise?
    is it just gonna make an annoying noise for a second when I start the car or is there a risk of it causing more damage?
    basically is it worth fixing?
  8. Duktor
    Duktor Member
    282
    Wasnt vvt introduced on the bam engine and thats where the extra 15 gee gees came from circa 2003 model the amk on a facelift is 210 as far as i know ?? maybe someone can clarify ?
  9. jojo
    28,856
    3,516
    vvt was introduced to help emmissions, it doesn't give you any more power, that comes with the engine mapping. The S3 only came with '210bhp' so as not to steal sales from the more expensive(and more profitable) TT225, but when the TT got the 3.2 V6 unit(250ps), the S3 got it's full fat 225.
  10. Duktor
    Duktor Member
    282
  11. metricspaces
    metricspaces Member
    661
    I'd like to know this too. Anyone got any info on how worried we should be about the "tractor noise" when starting up?
    I've an APY engine, is it still 400ish for the part?
  12. metricspaces
    metricspaces Member
    661
  13. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Secondary air pumps are known to be noisy the rivets come loose so maybe...
  14. metricspaces
    metricspaces Member
    661
    And should I be worried about the secondary air pump if rivets have come loose? From what I've read it's nothing to be worried about, and it's a waste of time replacing it.
  15. s3dave
    10,110
    736
    they just get noisy, you can delete it i think
  16. Welly
    10,696
    127
    Nope, less than £200 for the APYs
  17. Welly
    10,696
    127
    Yarp, you can indeed, although a bitch of a job to get the pump out!
    Mine lives in the circular file now, waste of time and weight IMO.
  18. metricspaces
    metricspaces Member
    661
    F&%k :) ! One benifit of owning an prefacelift hehehe...I might be getting my head gasket done, so would it make sense to stick in a new one of these when everything is off?
  19. Welly
    10,696
    127
    I would agree. Prevention is better than cure...
  20. metricspaces
    metricspaces Member
    661
    Also, how to tell if the noise is coming from dodgy SAF pump or from chain tensioner?
  21. Welly
    10,696
    127
    You can simply unplug the SAI pump. It's on the front of the engine, big black cylindrical thingy with the pipes going to it. Pop the plug off to disable the system. Expect a fault code.
    NOTE: AMK and BAM engines DO NOT have the SAI system. If you have a noise on startup on either and AMK or BAM engines, it won't be the SAI.
  22. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    Have a read of this thread, very useful info.
    http://www.audi-sport.net/vb/a3-s3-...intermitant-rattle-tapping-start-up-cold.html
    Before you go and splash out on a cam chain tensioner replace your oil pick pipe and maybe your oil pump too. The reason being is because the cam chain tensioner operates via oil pressure, therefore if its not getting any oil pressure then the tension will lose its tension slightly so the chain will rattle on the guide slightly.
    Im replacing my oil pump in the next few days. You can check your oil pressure via vag com but it only says when its ok or less than minimum. In module 17, look in group 2 on the measuring blocks and it will say if your oil pressure is ok or less than minimum. Check the pressure on idle after you have had a 30 minute drive or so and see what it says at idle, then check what it says at a steady 2000 rpm on idle.
    Nathan
  23. metricspaces
    metricspaces Member
    661
    Cheers for that info. Are you replacing your oil pump as a cautionary messure, or because the pressure is too low?
  24. S3 Nattie
    1,599
    Well ive been getting a 16396 cam fault code for quite a while now and it only seems to be coming up when the oil pressure is low (less than minimum according to vag com). So I believe the code could be due to the tensioner is not having enough oil pressure to allow it to adjust sufficiently and then bring up the code, or could be mis-timing of the cam chain but thats not the OP's problem.
    I can get an oil pump from GSF for £55 and a oil pick up pipe for £7 from TPS so its pretty cheap for piece of mind. If your pick up pipe is blocked or your oil pump is tired then it will starve the engine of oil and the first part of the engine to suffer is top end therefore the tensioner and thats why they tend to rattle.
    Changing the oil pump is really easy on a 1.8T. If you know how to get the sump off then the oil pump is held in with three bolts.
    Nathan
  25. danger S3
    danger S3 Member
    362
    thanks guys, i think i will start by replacing the oil pump next time i drop the sump as its done 100k miles so it will be a wee bit tired and its like the heart of the car moving the oil round and see if that helps with the tensioner.
    if it doesn't help then its not like ive wasted the money on the oil pump as it was tired anyway
    I take it the tensioner is a replace it job rather than a give it a good clean up job?
