Will a 18x8J 5x112 ET30 fit an S3 using a 20mm hub adaptor? Hope so
Alex C Well-Known Member VCDS Map User Joined Jan 26, 2010 Messages 3,434 Reaction score 417 Points 83 Location Lizard, Cornwall Apr 15, 2010 #1 Will a 18x8J 5x112 ET30 fit an S3 using a 20mm hub adaptor? Hope so
jojo Looking for Boost! Staff member Moderator Joined Sep 4, 2003 Messages 29,115 Reaction score 3,862 Points 113 Location Solihull, Midlands Website www.audi-sport.net Apr 15, 2010 #2 They will be ET10 offset with the hub adaptors fitted mate, and you will command with the amount of poke you are running with this set up! Basically, they will fit, but they will either be level or poking out a bit from the arches. Aim for ET20-35 to be safe
Prawn My other car is a MINI!!!! Joined Dec 8, 2006 Messages 12,100 Reaction score 4,340 Points 113 Location Eastleigh Website twitter.com Apr 15, 2010 #3 To add to what jojo said, at ET10 and 8J you're very likely to get rubbing problems on the back, which obviously isn't great news.
Alex C Well-Known Member VCDS Map User Joined Jan 26, 2010 Messages 3,434 Reaction score 417 Points 83 Location Lizard, Cornwall Apr 15, 2010 #4 Thanks Jojo, thats what I thought, a bit tight. They would have been fine if they were 5x100 but they aren't thanks for the reply tho
Alex C Well-Known Member VCDS Map User Joined Jan 26, 2010 Messages 3,434 Reaction score 417 Points 83 Location Lizard, Cornwall Apr 15, 2010 #5 dammit, sorry, wheel spec wrong as well, there 8.5". So definately a no no
Alex C Well-Known Member VCDS Map User Joined Jan 26, 2010 Messages 3,434 Reaction score 417 Points 83 Location Lizard, Cornwall Apr 15, 2010 #6 When you say rubbing Prawn, do you mean they'll rub the wheel arches or the running gear? Arches i guess?
jojo Looking for Boost! Staff member Moderator Joined Sep 4, 2003 Messages 29,115 Reaction score 3,862 Points 113 Location Solihull, Midlands Website www.audi-sport.net Apr 15, 2010 #7 Cookstein said: When you say rubbing Prawn, do you mean they'll rub the wheel arches or the running gear? Arches i guess? Click to expand... Wheel arches bud, the lower the offset, the more the wheel goes outwards.
