Another wheel question
H17YD L Feb 12, 2013
  1. H17YD L
    H17YD L Active Member
    383
    76
    Does anyone know if these wheels will fit my S3 I presume they are 5x112 but don't know about the offset etc
    They are off an A4 s-line and are 18" is all I know
    Thanks guys
  2. Kash3838
    Kash3838 Member
    185
    19
    The offset should be stamped on the back of the wheel. Depending on the a4 they are off, I think the offset on them is low. Would have to check on that
  3. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    Think the standard offset for A4 wheels is 43 (I could be wrong though). If this is the case then yes, they'll fit and fill the arches much better than A3 wheels with a standard offset of 54.
    But as said, the offset will be on the back so ask before buying.
  4. H17YD L
    383
    76
    Cheers guys! I'll get in touch with him
  5. sliced
    sliced Drive safe, stay alive.
    1,556
    334
    not sure if it helps but the part number is 8K0601025Q
    you should be able to ring up audi and ask them?
  6. H17YD L
    383
    76
    Thanks for the part no. I'll speak to Audi after
    Is et29 offset going to fit, they're off an A5 18x8
  7. sliced
    1,556
    334
    mate thats going to stick out by a mile
  8. H17YD L
    383
    76
    Lol cheers for the heads up! Back to the drawing board.
    So what should my ET be between 40 an 55 to fit right? Just seen some more off an A5 with an ET of 35 but they're probably gunna stick out too far aren't they
