Another Temp question
gaz71 Dec 31, 2009
  1. gaz71
    gaz71 1.8T Quattro Sport AJL
    286
    I know that there have been lots of threads regarding Temp readings but I hope that someone can give me a hint as to the issue I am having.
    I recently replaced the Temp sensor and Thermostat. This resolved my initial problem of a Temp reading of 70. While driving around town the temp sits at 90 but when on dual carriageway the temp drops to 70 again. Is this a normal occurrence? I have not noticed the temp doing this before but I may have missed this. Will this affect the running of the car, i.e over-rich mixture while temp reading 70?
    Any thoughts from the Audi Jedi out there?
    Cheers :icon_thumright:
  2. Matt82
    Matt82 Active Member
    2,365
    the temp should not drop, id say its still a dickie stat
    where did you buy the stat from?
  3. yendall24
    yendall24 Member
    571
    never take for granted that a new part is a good part in the past i have replaced two thermostats on my cars only for them to be faulty so now i pay the extra and get them from audi i am not saying audi thermostats cant be faulty its just that i have yet to get a bad one
  4. Matt82
    2,365
    word for word what i would have said
  5. CraigG
    CraigG Member
    190
    the temp will vary with load, but the dash has a buffer built in so it shows exactly 90 for any temp in the "normal" range.
    If its dropping to 70 the stat isnt right.
  6. gaz71
    286
    Yeah, the problem is that after 1/2 hr motorway driving the temp is 70. Comes straight back up to 90 about a minute or so after coming off.
    Looks like I'm off to stealers for another stat.
  7. Geeman
    Geeman Low Life
    1,318
    Mine is playing REALLY silly buggers now too.
    Was sat at 60 degrees, so assumed temp sender was faulty. Spent £25 for a genuine Audi item... I've just put it in and no difference. I did this on a warm car too... had been running for a good 20 mins.
    Strange thing though... engine hot, coolant hot... but the coolant in resevoir was stone cold.
    What are your thoughts on that?
    I'm getting heat in the car... so no problems there.
    Very strange. :keule:
  8. gaz71
    286
    Just took mine out for a run to see how it's performing.
    Driving round up to 50mph and no problems, warmed up quickly and sat bang on 90, even with A/C on (nice, warm and cozy). Hit the dual-carriageway, took it up to 70mph and within a couple of minutes the temp had dropped to 70. Came off dual-carriageway, dropped to 40mph and the temp started to rise almost immediately, sitting bang on 90 within a couple of mins.
    Again, just to point out that this is different to my initial problem where the temp sat at 70 constantly. Stat and temp sensor were replaced and new coolant added.
    I know I'm repeating myself but I just wanted to make sure that I was correctly describing the problem. I don't want to get another stat just to find out that I have a different problem.
    Is there anything else that could be causing this?
  9. Matt82
    2,365
    use the climate control to see what temp the ecu us reading and then take a deep breath because it really sounds like its your stat
    do you drive an s4?
  10. gaz71
    286
    Not sure how you do that, any clues?
    No I haven't got an S4 just a lowly A4
  11. Matt82
    2,365
    press the recirc button and "up" at the same time
    the screen goes really bright. press temp up to get to option 49 and then recirc again shows the ecu temp sensor reading
    therein lies your answer
    this week youll be over joyed at having an a4 because a stupid s4 requires the engine to be stripped back to the cambelt off to be done, thats how i did mine, but you may be able to do it with the cambelt in place
    that doesnt matter though, yours will be a doddle in comparison
  12. aragorn
    18,022
    718
    Yer its dead easy on a 1.8T. Sounds like a duff stat.
    Its letting too much water bypass it under normal conditions, hence the temp is dropping when the airflow increases.
  13. Geeman
    Geeman Low Life
    1,318
    What's the first "up" button - fan speed or temp...?
    How do you then get out of that mode?
  14. Geeman
    Geeman Low Life
    1,318
    My thermostat will be getting swapped out tomorrow... the temp sender's been changed and no difference. Along with a new MAF (think mine got damaged in the fire)
  15. aragorn
    18,022
    718
    The first "up" is the blow direction control, the one that lets you select the windscreen.
  16. gaz71
    286
    Right, I know what my first job in the morning is then, check temp on ecu. Then I think I'm going to have to go to the stealers for a new stat, again
  17. gaz71
    286
    Just been out on a run. ECU reading 64-71 on dual-carriageway so it's off to stealers
  18. Broken Byzan
    13,237
    465
    If its running too low it means it's going to explode into flames, you better sell it fast to me as i am flame proof !!!
    LOL
    Seriously sounds like a dodgy stat, despite it being new. You could try the old cardboard/tin foil on the grille mod ! like old Escorts/cortinas etc.lol
  19. Geeman
    Geeman Low Life
    1,318
    Off Topic... but Mark... where in Souh Wales are you? I'm coming to Ross on Wye tomorrow to pick some rims up. Anywhere near you?
  20. aragorn
    18,022
    718
    Hes further south than that, just beside that rediculously expensive road bridge!
  21. Mattfaced
    Mattfaced Member
    77
    Just done the stat on mine temp gets to 90 and stays there in traffic or driving, not a big job to change the stat a garage did mine in under an hour
  22. Geeman
    Geeman Low Life
    1,318
    Right then... got the stat, just need to find time to do it.
    That'll be after my 500 mile road-trip tomorrow though... lol
  23. Broken Byzan
    13,237
    465
    I am located at Np26 ... just to give you an idea, i would say its probably 40 miles from Ross, but a good hour journey.
    From Ross thats the M50 way you went Aragorn, no bridge involved
  24. gaz71
    286
    Right that's me £24 lighter, good old stealer :sob:
    Early start tomorrow to change that, good job it's good weather at the moment :cold:
  25. gaz71
    286
    Brrr it was cold this morning but not icy so good, good. Put new stat from stealers in and all seems fine now. Had a quick run on dual-carriageway and temp sat nicely around 90 :arco:
    Slight bummer tho, was cruising at 70 and spotted a "Traffic Safety" camera van, a.k.a Police cash donation device :busted_cop:, so will now spend the next two weeks sweating every time the postman comes :sadlike:
    Oh well, at least the car is sorted
  26. Matt82
    2,365
    i tried to post yesterday but my internets crashed... basically new vag parts come with a 12 month warrenty. i think they should have replaced it free
    good things its fixed!
