another suspension question!
btmotorsport Aug 18, 2008
  1. btmotorsport
    btmotorsport Soon be christmas!!!!!!!!!!
    164
    just a quickie! I want a new setup for my 1.8t sport, will a mk4 setup work? I'm sure it'll fit but will the spring and damping rates be right?
  2. abdus
    abdus Top Gear VCDS Map User
    1,827
    yep. I ahve that setup on mine
    Eibach springs and GAZ adj dampers :)
  3. btmotorsport
    164
    cracking stuff, how do you get on with that setup?
  4. coleen
    coleen New Member
    26
    as far as im awake the model b4 mine (2006) should have the same fitments as th likes of a mk4, bora, skodia octavia and a few more
  5. abdus
    1,827
    nothing to complain yet. :)
    the adjustable dampers are excellent and the settings on them do make a difference :)
  6. btmotorsport
    164
    how much did they cost and low do they go?
  7. S3mad
    S3mad Dark Knight
    946
    will mk4 golf lowering springs fit on a a3 ?
  8. abdus
    1,827
    lowered by 25-30mm.
    Eibachs- £120
    GAZ- £175
    yes...mk4 will fit on an 8L
  9. S3mad
    S3mad Dark Knight
    946
    ok so the mk4 golf ones fit straight on the a3 ?
    just checking as seen some for sale
  10. abdus
    1,827
    YES, mk4 golf will fit on an 8L a3
  11. S3mad
    S3mad Dark Knight
    946
    Is it ok to go around 35mm on standard parts apart from springs?
  12. abdus
    1,827
    would be better to get uprated shocks.
  13. S3mad
    S3mad Dark Knight
    946
    yes but my shocks are fine !
  14. S3mad
    S3mad Dark Knight
    946
    the springs look very small on the back of the car are you sure the mk4 ones fit on a audi s3
  15. j4jon
    j4jon Member
    704
    The original statement is correct the FWD mk4 golf suspension will fit a FWD A3.
    The FWD mk4 golf will NOT fit an A3 Quattro or an S3
    The 4Motion mk4 golf will fit an A3 Quattro but will NOT fit a FWD A3
