Another RNS-e vag coding question A4 Cab
Blackie Feb 26, 2012
  1. Blackie
    Blackie Active Member
    697
    67
    Hi chaps
    Just installed the new Navi in Mrs B,s Cab
    I have also installed a bluetooth module
    The system is the RNS-e
    Bluetooth module
    MFSW
    No other items in the car
    Coding on Vag is 0403715 on the Navi section
    and 0011402 in the 77-phone section
    At the moment the names dont show on the clocks & the wheel does not scroll the numbers but the fuel guage light is on so i didnt know if that needed to be out before it worked
    Any other changes that need to be made
  2. gary3306
    gary3306 Active Member
    989
    41
    You need to fuel it up to get anything other than the low fuel light on.
    You have 0403715 as your navi coding, change it to 0413715. The figure after the 4 denotes if its an A4 saloon or A4 cab. At the moment yours is set as saloon (0), 1 is for cab.
    Your Tel code looks ok to me though.
  3. Blackie
    697
    67
    Cheers Gary
    Will fuel up and try it
  4. Blackie
    697
    67
    Very strange
    I changed the coding as you said & now even with the ignition off & the key out the bluetooth will not switch off. I have to disconnected the bluetooth from the phone . It will also make a call even with the car turned off so the unit is powered up all the time
    It never used to do this in the A3 & i have used all the same equipment & leads
    Can anyone shed some light on it please
  5. gary3306
    989
    41
    You may need to move pins on the quad lock. PM Nigel (NHN), he's (one of) the guy for this.
  6. NHN
    29,596
    1,782
    Change phone to 0011802
    Did you connect up the infotainment bus wires from BT module?
  7. Blackie
    697
    67
    Just used the Kufatec lead that came with it Nigel
  8. NHN
    29,596
    1,782
    The loom maybe ok, but my experience of there looms is rubbish, always wired wrong at some point, but try coding then check wiring if still not right.
  9. gary3306
    989
    41
    Told ya! :)
  10. NHN
    29,596
    1,782
    lol, Gary's a top lad :)
  11. gary3306
    989
    41
    Not top enough, otherwise I would have given him the correct code for his tel :)
  12. NHN
    29,596
    1,782
    He hasnt said its fixed it yet mate so lets not jump the gun lol :)
  13. Blackie
    697
    67
    Cheers gents. I will check when i get home tonight
    Hopefully the coding will sort it otherwise its bloody head unit out again. I presumed it may be the quadlock & not the Kufatec lead as it worked ok in the A3 albeit with a different quadlock
    Should have bloody kept it & used the other one in the A3
    Damn
  14. Blackie
    697
    67
    Ok
    The Bluetooth now works thank you but the steering wheel doesn't do any function for the phone.
    I take it there is another coding problem ?.
  15. NHN
    29,596
    1,782
    Then code the steering wheel.
  16. Blackie
    697
    67
    Oh god. Right I'll have a go and report back.
    It really is a never ending trial of coding :)
    Its good fun really
  17. Blackie
    697
    67
    Right coded the wheel with a 3 for radio/phone
    Still doesn't work and the names don't appear inbetween the clocks it just says phone. I'm wondering if that's all I does.
  18. Blackie
    697
    67
    Mrs B tried the phone this morning and all apears fine apart from the selection of callers from the wheel. The volume function for the phone works from the wheel but not the selection of names which must be done from the RNS.
    The B7 Cab has the red clocks but my S3 has the new white clocks. I dont know if "phone" is all the red clocks are supposed to show & the RNS and BT unit are more modern than the clocks.
    I did have a look to see if the clocks had a program setting to display the names but couldnt find it anywhere.
    Thanks for the help up to now gents, much appreciated.
  19. gary3306
    989
    41
    Just to clarify; I take it you are pressing the 'MODE' button on the steering wheel to bring your phone book entries up? The mode button is to switch the DIS display between showing the radio station/track name and the phone book. Sorry if it sounds like I'm trying to teach you how to suck eggs, but sometimes it isn't obvious what people are and aren't doing. Its sounds like its coded up correctly, so may just be something as simple as that.
  20. Blackie
    697
    67
    Yes mate
    I try to replicate what the S3 does ie press the mode button so the phonebook comes up instead of the radio station. ( the radio is fine & scrolls like it should & alters the volume)
    The phone (when active) can be turned up using the volums wheel
    The only thing not working is the mode button that changes radio to phonebook entries.
    I have found another thread on this but again will have to wait until tonight to have a fiddle with it again
  21. gary3306
    989
    41
    It has to a coding issue then. Nigel might keep us right here but I have a couple of suggestions to try. First one;
    go into 'NAVIGATION' and then into 'ADAPTATION'. Look at channel 136 and see what value is stored. It should be 00013 for RNSe high (RHD cars). If not, change it to 00013 click 'TEST' then 'SAVE'
    Next; Go into Telephone (77), then 'ADAPTATION' and look at channel 134. This should be a '0'. It may say '1'. Change it to 0, 'TEST' then 'SAVE'. I think this allows hands free use without the phone having to be plugged into the cradle. I'm not saying this will definately fix the issue but its worth a try.
    EDIT: For anybody reading this who knows a bit about VCDS and thinks, 'What the heck is he talking about...' I'm just learning myself and like these sort of threads because I learn from them. So don't berate me if I'm wrong :)
  22. Blackie
    697
    67
    Cheers Gary. I,ll have a look later & report back
    I take it i,m correct with the 3 in the wheel program & not the 4 as the speech mod isnt installed ?
  23. gary3306
    989
    41
    Or there is this as Nigel says;
    [h=2]Coding[/h]
    • 00?xxxx: Transmission
      • 0 = Manual Transmission
      • 1 = Automatic Transmission
    • 00x?xxx: Steering Wheel
      • 0 = 3-Spoke, w/o Tiptronic, w/o Multi-Function
      • 1 = 3-Spoke, with Tiptronic, w/o Multi-Function
      • 2 = 4-Spoke Multi-Function (with Radio Control)
      • 3 = 4-Spoke Multi-Function (with Radio/Telephone Control)
      • 4 = 4-Spoke Multi-Function (with Radio/Telephone/Voice Control)
    • 00xx?xx: Tiptronic/Heating
      • +1 = Tiptronic on Steering Wheel
    • 00xxx?x: Cruise Control/Board Computer
      • 0 = no Board Computer, no Cruise Control
      • 1 = Board Computer, no Cruise Control
      • 2 = no Board Computer, Cruise Control
      • 4 = Board Computer, Cruise Control
    • 00xxxx?: Rear Wiper
      • 0 = w/o Rear Wiper
      • 1 = with Rear Wiper
    Courtesy of the RossTech Wiki.
    Audi A3 (8P) Steering Wheel - Ross-Tech Wiki
  24. gary3306
    989
    41
    Ahh so you've coded the wheel. 00x3xxx would be right then if no voice control.
    We'll get to the bottom of it yet :)
  25. Blackie
    697
    67
    Yes i did that last night so Nigel would see that i am making an effort & at least trying to find my way around it. It really is a minefield, you alter 1 thing and then need to alter about half a dozen more.
    The other head scratcher was where the mic is on the Cab. I took down the light & there is no space for it in there so i have temp placed it on the left pillar for now
    I did alter my S3 as well last night & turned on the beep for the locking via the long coding.
  26. gary3306
    989
    41
    I really do think then, that the adaptation value for having hands free work without the phone being plugged in is the answer. It seems like you everything coded up right. There are two options in Tel Adaptation, one is to have handsfree work when bluetooth connected without the need to have the phone engaged, and the other is so that handsfree is only active with the phone engaged. Being able to scroll through your phone book without the phone being plugged in, is handsfree to me....
    I think your adaptation value is set for the second option above. You need to be able to operate your phone whilst its still in your pocket or wherever else it might be.
  27. gary3306
    989
    41
    HOW WE DOING NIGEL!!!? :think: :sm4:
  28. NHN
    29,596
    1,782
    Try checking instruments 17 & check adaptation channel 062 to see if telephone is enabled on the bus:
    Audi A4 (8E) Instrument Cluster (8EC/8ED/8HE) - Ross-Tech Wiki
    Channel 062: CAN-Databus Infotainment (Installation List)
    • +00001 = Radio (Optional)
    • +00002 = Telephone (Optional)
    • +00004 = Navigation (Optional)
    • +00008 = Telematics (Optional)
    • +00016 = Intrument Cluster (Standard - only coded with 2nd Component)
  29. NHN
    29,596
    1,782
    For me, very well mate, at least you guys are trying to learn & reading, which I respect :)
  30. gary3306
    989
    41
    Well between us all we're bound to sort it eventually lol
  31. Blackie
    697
    67
    I think thats the one Nigel
    I enabled the ch62 & it now works
    Its value was 17 as its never been coded for the Nav when it was installed. Am i corect in thinking it should be 23 ?
    =23 ?
  32. gary3306
    989
    41
    This has all gone down in my little book. Jobs a good 'un :)
  33. NHN
    29,596
    1,782
    Just remember blackie, there is a Thanks button on bottom of each post :p
    If I get enough thanks, I get a set of steak knives engraved audi-sport lmfao
  34. Blackie
    697
    67
    Excellent . I will be scrolling down the thread tomorrow and clicking the thanks buttons .
    Thanks gents for helping me to sort this out. Mrs B is a happy bunny
  35. gary3306
    989
    41
    I love it when a plan comes together.
