Another question B7 (Lights)
zollybosher Mar 1, 2012
  1. zollybosher
    zollybosher Member
    58
    Bit of a strange one coming from the B6 I now have the B7 and my lights options are off,auto side and full beam on the dial, however I have noticed that even when the dial is placed in the auto position my side lights come on when I am driving. This also applies to if I have the dial to the Off position, So question is what is going on is this normal and just a safety feature, or something else and does it have a negative impact on the normal wear and tear of the bulbs?
  2. kite
    kite Member VCDS Map User
    676
    Sounds like your lights have been coded with sidelight DRL's
  3. Richardesty
    Richardesty loves quattro
    742
    20
    Sounds like a fault to me......
    Side lights should be:
    Off - off
    Auto - off, unless it's dark
    Side - on
    Full - on
  4. Richardesty
    742
    20
    Good point
    Is it fronts only?
  5. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,474
    646
    bit of codeing should sort it out
  6. razza1
    razza1 Well-Known Member
    3,033
    799
    Sure its your side lights and not your drl's? check if you have a small switch next to the light switch that has a 1 and a 0 on it. 1 being on.
  7. zollybosher
    zollybosher Member
    58
    Whey hey, seems like I have another toy on my car they are DRL lights checked them this morning and well they do as it says on the tin. thanks to everyone who advised
  8. razza1
    3,033
    799
