Another pesky CIL light!!
nickrex Mar 16, 2009
  1. nickrex
    nickrex Member
    46
    Hi all. After thinking all has been well with the car for a couple of months, it has once again thrown a wobbler and given me the CIL light. Ran Vagcom and it is showing this.
    Address 01 -------------------------------------------------------
    Controller: 06A 906 032 FC
    Component: 1.8L R4/5VT 0002
    Coding: 11500
    Shop #: WSC 06435
    WAUZZZ8LZ1A087100 AUZ7Z0Y1760712
    2 Faults Found:
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-00 - -
    17545 - Shareware Version. To Decode all DTCs
    Now I know that the 17545 error is system running rich and I have got a dodgy thermostat at the moment(Usual sitting about 70 degrees trick) which a haven't got round to changing yet. The DV was replaced 3 months ago and I cant find any splits so I dont know why this is showing as faulty.
    My guess is that the thermostat is the culprit for the rich running but if anyone has had a similar problem then I would appreciate any feedback. Also could the 2 faults be related? I have cleared the codes for now and the light is out but time will tell I suppose. In the meantime I really must get round to the dreaded thermostat job!
    Look forward to any advice.
  2. leshkin
    leshkin Hold my beer... VCDS Map User Gold Supporter Team Sepang Audi S3
    2,452
    1,361
  3. leshkin
    2,452
    1,361
    PS: Find someone with a full version of Vag-Com as you might be getting more errors than the shareware version will show.
  4. AS3TOM
    AS3TOM Member
    190
    where can you get the full version of vagcom from?
  5. leshkin
    2,452
    1,361
    Well, what I meant was, get an official VagCom dongle from Ross-Tech, which will activate the latest version of VagCom for you. http://www.ross-tech.com/
  6. nickrex
    nickrex Member
    46
    Hi there. The MAF is virtually brand new and as I've said the DV is virtually new aswell. I suppose The next thing would be to check closer for any hose splits.
