Another niggle to iron out on Power Steering
tonybolony Sep 7, 2013
  1. tonybolony
    tonybolony Member
    138
    So the two ends on my power steering were a bit frayed (ones under the bumper that join the metal type cooling thing)
    anyway i cut them back a bit and now there sorted, but now the piper coming from the engine at front (with the factory metal crimp) is now leaking, so i need to jubilee clip this, is there an easy way to get to this please? , before i start stripping the car down when i dont need to?
  2. aragorn
    17,956
    701
    Do you mean the high pressure line from the pump to the rack? If so, your not sealing that with a jubilee clip!
    If you mean the pipe from the pump to reservoir, then it should be easy enough to do from underneath.
  3. boost-addict
    boost-addict Well-Known Member
    1,000
    second that, you need a new pipe. and its a little bit of a ***** to get to
