Another hybrid conversion thread....
Welly Sep 14, 2010
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Well, some not so good news today.... but not the end of the world.
    My new card (finally) arrived this morning, so I can now fund this project without breaking into my hard earned savings. Again.
    So, being proactive, I thought it best to pay CR for the work now, so that they can just send the thing to me when it's done. That was fine, and I'm all fronted up with the dollar dosh beans.
    However, when asked for an expected delivery date, I was given the reply to expect the unit on Wednesday.
    However, it's not the end of the world. I know CR are short staffed at the moment, so cutting them some slack I don't mind.
    I will still be whipping the head off on Monday as planned, because then it gives me time to fiddle with the other bits and bobs I want to change.
    At least I can (maybe if I can be bothered) take my drivers door apart and finally fix my broken driver's window....
  2. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Ah, shame that buddy, but like you say, by the sounds of recent contact from Paul etc sounds like they are really up against it...
  3. Welly
    10,696
    129
    Indeed, you can't say fairer. I'm sure they'll get it out as fast as possible - it's just a bit of a bugger for me.
  4. Welly
    10,696
    129
    Well, I gave the K04-022 it's last hoorah tonight on the way home from the girlfriend's. IATs were down to 8 degrees C and it was going really well bless it - if a touch smokey....
    Starting work tomorrow afternoon - will be chucking an engine flush through the engine to try and remove some remnants of AVS on the engine that's now in there. Then I will be dropping all the fluids out of the engine and leaving to drain overnight before kicking off on Monday AM.
    Bring it on :)
  5. Welly
    10,696
    129
    OK.... kicking off Monday AM went a bit wrong.
    Dropped my engine flush in earlier on, and then dropped out the oil and am leaving it to drain overnight...
    Then I thought I'd just take a few bits and bobs off.... and then that turned into taking most of the bits required to remove the head off...
    This is how I am leaving the engine tonight ready for the final bits tomorrow...
    VXR Injectors vs. S3 Injectors.
    Random dead wasp I found in the recess between inlet ports on 1 and 2.... Thats new. Must of thought my car was it's mummy....
  6. finesse
    finesse Active Member
    2,805
    good luck welly
  7. Welly
    10,696
    129
    Cheers dude. :thumbsup:
  8. jimes
    jimes Member
    30
    are the rods on the bam tht bad? how much boost does a stage one go to?
    Bill i remember talking to you and kevin by tims car at combe and kevin said he had bent rod but im sure hes putting more on them then i would on my s3 with a stage 1 (know his werent std)
    i thought my impreza engine was made of chocolate!
  9. Welly
    10,696
    129
    Its only the rods that are the weak point mate. In theory, Stage 1 power should be OK - it's the higher mileage engines that tend to suffer more.
    One of my rods bent on Stage 1 power.
  10. Welly
    10,696
    129
    Eventful day.
    All my stuff ordered from Euro Car Parts has now arrived which is a relief....
    Much as you'd expect though to be honest. Got the head and old turbo off in about an hour as I did half of the work yesterday.
    Lots of oil floating about in the pipework, inlet manifold, various other places where oil shouldn't be really. Other than that, lifting the lid off was uneventful. Head gasket was A OK which was good, and has now been placed in the circular file, along with all the other gaskets etc.
    The turbo wasn't in the best nick.... And that's being kind. Photos below show the damage and the severity of the cracking through the hot side.
    Comp and turbine wheels look to be in OK condition, however the amount of play in the shaft is awful. Literally has about 2-3mm in and out play on the shaft, suggesting the core has collapsed.
    Have also found various other issues with it - the actuator is shagged. Totally. One of the bolts that holds the turbo together has come loose, and is where my oil leak has come from, allowing oil to leak out and down the back of the engine. Again, this is obvious by the amount of cooked oil around the join.
    Other than that, everything is cool. Some slight detonation marks on the piston from where oil has been getting in and been getting burnt. The pistons were pretty crusty from oil contamination. I've given them a quick clean up, but there isn't much point in going too mad.
    By 1 PM we were getting bored and were trying to do stupid stuff like make the turbo boost using a high RPM drill. Epic fail :(. Fun though.
    Gave the engine bay a good clean up, got all the crusty oil off of all the back of the engine.
    Cleaned the head, got all the remnants of old head gasket off of it.
    And to be honest, that's it for the day now, nothing more I can do until the Hybrid arrives from CR.
    Now retired to the lounge to while away the rest of the day posting up here, and playing on COD. Ahhhhh.
    Anyway - to the photos....
    Starting the day....
    Damn Turbo Support Bracket.... It's SUCH an arsehole.
    Turbo off.
    Poor old thing - not looking it's best.
    Turbine & Compressor wheels.
    Damage to the hotside.
    The bolt that decided it didn't want to be tight anymore, and the crust of oil from the leak resulting leak.
    The head.
    The engine bay after it had received some love....
    S3 vs VXR Injector
    VXR Injector fitted to S3 Inlet Manifold. The injector is a great fit into the manifold, and the shorter nose should help with better fuel atomisation, as well as not impeding air flow through the manifold.
    Thats it for today... all I expect to see for the rest of the day is something similar to this....
    More tomorrow....
  11. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    get on the roof man! and use a real gun!
  12. Welly
    10,696
    129
    I was only stood there to take a quick photie.... :(
  13. badger5
    9,554
    2,027
    the gap around that turbine wheel is huge... some serious erosion gone on there...
  14. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,294
    372
    that thermal scope is rubbish!! :)
  15. superkarl
    superkarl MAN OF STEEL
    9,571
    2,464
    very very important question for you!........ playstation, or xbox?
  16. Alex C
    3,294
    372
    playstation... press and hold square to pick up SCAR-H Bling
    dont stamp on your controller again Welly
  17. Welly
    10,696
    129
    Playstation.... LOL.
    And I love my Thermal Scope....
    I must admit, Akimbo Rangers or 1887s is more my thing, but they're useless on a big map.
  18. Welly
    10,696
    129
    I'm going to bring it up to show you tomorrow night dude, the thing is poorly - but good to have a bit of a laugh at. This one certainly wouldn't be a hybrid candidate...
  19. superkarl
    9,571
    2,464
    congrats right answer! lol
    whats your username? mine is superkarl. il go on now.
  20. Welly
    10,696
    129
    welly1986. Add me up....
  21. Welly
    10,696
    129
    :sorry:
  22. superkarl
    9,571
    2,464
    will do!
  23. Dane
    4,086
    182
    :p haha That was my week last week.
    On a more relavent note thats one poorly looking turbo, but good information for the those of us interested in this work a bit further down the line, cheers! :thumbsup:
  24. superkarl
    9,571
    2,464
    im more concerned about kicking wellys ass on cod seein as though once this build is done i won't beat him in a race!
  25. JD09
    3,096
    46
    Lol, whizzed through the post about the car, then was confronted with lots of chatter about something called FISH (;)) and what console you play it on!!!!
  26. Welly
    10,696
    129
    :lmfao:
    I agree, not all on topic chatter....
  27. JD09
    3,096
    46
    Your sig needs updating... "it's being fixed, again, but better this time. Innit"
  28. Welly
    10,696
    129
    :thumbsup: Done.
  29. JD09
    3,096
    46
    Lol at doing it word for word. Believe that was copywritten :sly:
  30. superkarl
    9,571
    2,464
    laugh my ass off that sig is gold!
  31. Welly
    10,696
    129
    Update:
    Turbo is en route as of 4 PM this afternoon.....
    :thumbsup:
  32. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Jealous much :racer:
  33. badger5
    9,554
    2,027
    welly.
    i need to check the actuator opening pressure on this.. (for the map)
  34. Welly
    10,696
    129
    Will phone you now....
  35. badger5
    9,554
    2,027
    sorted and adjusted to how it should be now.
    good luck fitting it welly
  36. Welly
    10,696
    129
    Evening all...
    Another long, yet productive day today. It started at 8.30 this morning when, out of the window, I saw a FedEx van turn up. After a brief jump around session I went downstairs to greet some miserable twat with my new turbo...
    So, I got it out and drooled all over it.
    So I set about having some brekkie and faffing about doing this and that around the house until my mate turned up.
    So, then we cracked on. As you will have seen, I had to pop up to Bll's at 12.30 and take he turbo with me for him to test the actuator preload. Therefore we couldn't start fitting the turbo until after this.
    So, the fun job of installing new water pump, belt tensioner damper and removing the engine mount to fit the new belt round. This was made massively easy by figuring out that, with the head of, you can slide the engine mount out of the engine bay from the top, rather than the bottom. Took about an 80th of the time it normally does.... Welly's Top Tip for the day....
    Anyway, photos below:
    Cambelt area with nothing in....
    Old belt components. :bye:
    New vs Old tensioner damper.
    All new components fitted.
    At this point, rain stopped play, and we had to leave to get to Bill's anyway.
    So, once back from Bill's (Thanks for meeting me at lunchtime dude :thumbsup:) at about half 1, we cracked on with fitting the turbo...
    Did all the prep work to get it on, such as winding the turbo studs into the turbo, and then fitting commenced.
    Turbo support bracket fitted.
    Turbo all bolted up, with all oil lines and coolant lines.
    Then, on goes the head...
    Timed up...
    At this point, I popped off the piping to the intercooler to see how much il the old turbo had dumped in there...Quite a bit was the answer.
    VXR Injectors fitted to the injector rail and fitted to the inlet manifold
    My Billy Bodge to get the rail o fit with the different sized injectors...
    Engine back together and running... Happy days.
    So, the engine is back together and running fine.... So far anyway.
    Need to do a few bits and bobs of tidying up tomorrow during the day, and then the hardware install is all completed.
    Up to Bill's on Saturday AM for first session of mapping - I cannot wait.
    Will post results of first drive up when I take it out tomorrow as well, hopefully with logs.
    Nearly there....
  37. <tuffty/>
    21,686
    4,116
    Good work mate... hoping mine will be mobile Saturday too... just need to bleed the clutch and do a bit of a fix to my headlight...
    Take it easy with the driving though mate...
  38. Dani_B19
    9,343
    394
    Very nice work mate, but after all this welly, your still running the standard TIP, what you doing? haha.
  39. Welly
    10,696
    129
    Not for long bud, awaiting the arrival of my AutoBahn88 one. It's all paid for, they just ran out of black ones. They asked if I wanted another colour, but I don't, so I'm awaiting it's arrival....
    Hopefully won't be too long.
  40. Welly
    10,696
    129
    I will do mate, but need it back on the road to get about since the bloody quad is broken as well now.... D'oh.
    Just a quick logging sesh is all I will be doing before I disconnect the N75 and run it on actuator pressure.
