Another hybrid conversion thread....
Welly Sep 14, 2010
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Wow, they are a bit all over the joint..... Especially the huge drop in torque at 3000 RPM, it doesn't recover to the same level until 1500 RPM later....
  2. RobbieRolex
    RobbieRolex Member
    81
    I know, very strange, not sure what could cause this, it needs work, but at least its going in the right direction, TBO i would have thought i would feel that drop in torque on the road but i haven't, it pulls strong.
  3. RobbieRolex
    RobbieRolex Member
    81
    Forgot to add this was on a MAHA dyno on 95 octane, us poor farmers over here can't get anything higher in octane:yes:, still the Methanol would have added stability.
  4. <tuffty/>
    21,377
    3,939
    Not running on a 4wd dyno by any chance?
  5. RobbieRolex
    RobbieRolex Member
    81
    No, they have a 4wd and 2wd dyno there, why do you ask.
  6. Welly
    10,696
    129
  7. <tuffty/>
    21,377
    3,939
    Seen similar issues when S3's are ran on a 4wd dyno as the haldex has a spaz... Bill does all his mapping with the haldex fuse pulled in FWD only on these...
  8. Andrew@A.L.D
    3,879
    617
    Got the same kit and well worth the money at £300 for the 1 gallon tank kit
  9. badger5
    9,510
    2,004
    Hmmm, thats some weird old delivery... torque would be boost driven normally, does it spool then hold then go again?
    Do you have logs of it?
    regards
    bill
  10. RobbieRolex
    RobbieRolex Member
    81
    No Logs it was just a power run, i have been thinking about this and i would 100% feel this on the road, i think it was wheel spin, if thats possible
  11. <tuffty/>
    21,377
    3,939
    Yeah, seen this on Bill's dyno... warming up the tyres by holding on load and spraying the tyres with a little WD40 helps them stick better as does proper strapping...
    Did try strapping off the towing eye but the natural climbing action of the suspension when the engine came on boost would lift the car off the back roller causing a failed run and no coast down...
    Now we just strap from the transport holes on the floor pan of the car just behind the front wheel arch... not had an issue since...
  12. RobbieRolex
    RobbieRolex Member
    81
    jitvv likes this.
  13. Welly
    10,696
    129
    Well, well, well.
    Quoted from Bill on the Hybrid comparison thread:
  14. superkarl
    superkarl MAN OF STEEL
    9,496
    2,436
    get the sig changed lad! was just mentioning on the other thread the difference in torque delivery is great. how is it to drive? noticable?
  15. Welly
    10,696
    129
    Ummmm, feels quick....
    Different though. It spools much more like a big turbo now, and delivers it's power much more like one as well.
    It's not at full spool until around about 3.5K RPM+ but once there it just pulls and pulls and pulls. Torque delivery now is much more pronounced than it was before, but this is due to the boost holding on better.
    It feels like a BT car to be honest....
  16. superkarl
    9,496
    2,436
    not bad then, big turbo feel for less pounds and less fabrication. the later power delivery must be made up by the higher rev limit, the go lasts longer if you know what i mean
  17. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    The area under the graph looks very good now dude. I want to see this on a 1/4 mile to see what time and terminal speed you can get.
    Nathan
  18. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    is it laggy lower end then...
  19. Welly
    10,696
    129
    Me too.....
    Yes it is dude, quite noticeable under normal driving. Not a bad thing as the go further up more than makes up for it, and it means MPG should be better under normal driving.
  20. superkarl
    9,496
    2,436
    even if it is a little laggy lower down, this should be good for day to day driving surely, and when on track or whatever, shouldnt be hard to keep it where the power is.
  21. Welly
    10,696
    129
    No, the power isn't hard to find.
    My mate tried racing me up one of the 2 mile straights on the way back from Bill's. Wish I had a camera....
  22. S3 Nattie
    1,599
    I would have thought so be but thats probably because theres a bigger/consistent volume for the air now but once the turbo on boost it getting a nice amount of consistent airflow so can hold the boost longer and higher up.
    Nathan
  23. Welly
    10,696
    129
    I see you here Dani.... Yes, you do want one..... lol.
  24. Barks
    Barks Member
    337
    Thats some cracking gains Welly, Bills been working his magic
    I finally know which route to go now, IHI or Hybrid, Hybrid it is!
    Cheers for doing the experimenting so we can all benefit!
  25. Speedy Steve
    Speedy Steve Active Member
    1,258
    i can see a hybrid battle at pod coming on hehe all looking good welly i take it youll be at Bills for the RR day
  26. superkarl
    9,496
    2,436
    please let this happen
  27. Speedy Steve
    1,258
    well i need a new clutch first
  28. Dani_B19
    9,321
    390
    Who, me? haha. Have you seen the list ive already got!
  29. badger5
    9,510
    2,004
    airflows on one graph
  30. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    Wow! nice work, this has convinced me beyond doubt. Expect to see a lot of me Bill :thumbsup:
  31. badger5
    9,510
    2,004
    Now its worth mentioning this prototype was done for a car which had open cone induction kit.
    Its going to be tight on an OE airbox, but not having tried that I cant confirm how well it will fit..
    wellys S3 bung it in to check install below to show you what I mean:
    Comparison to an already good flowing silicon TIP which was what welly was running before swapping to the 3 inch jobbie
    those who want them: info thread here with prices> SEAT Cupra.net - SEAT Forum - View Single Post - full 76mm/3" k04 LCR/S3/TT TIP gauging interest..
    If folks let me know on this please so I can plan 1st production batch.
    :thumbsup:
  32. Dane
    4,086
    182
    Yes Diddly yes yes!
    I'm in! AMK S3.
  33. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    As mentioned on FB, great results. All if not most of the hats off to Bill! :superman:
  34. Welly
    10,696
    129
    LOL, gotta love the Facebook dude! :p.... Yeah, hats off to Bill I agree, he is, in fact, a little like Batman. I may start calling him Bruce Wayne.
  35. JD09
    3,096
    46
  36. Welly
    10,696
    129
    :lmfao:
    *pow* *zark* *splatt*
  37. s3dave
    10,110
    736
    Yes please sir.....
  38. badger5
    9,510
    2,004
    OMG!
    oh dear oh dear...
    fat man I could believe..... I do like my chinese and indian food
    :p
  39. Welly
    10,696
    129
    And what's wrong with that?
  40. badger5
    9,510
    2,004
    nothing aside from the excessive gravity I generate around me.
