another econ light!
tdisportuk May 5, 2009
  1. tdisportuk
    tdisportuk Member
    460
    Hello all
    my air con pump was broken, the part where the compressor plugs into the loom the clip had managed to break off so there was no way to connect it back up, not possible to weld it, so i managed to buy a like for a like air con pump, got it fitted econ light still on..could this be becuase it needs to be regassed?
    :wtf:
  2. pedders
    pedders New Member
    Yeah the econ light stayes as an indicator their is low gas.
  3. tdisportuk
    tdisportuk Member
    460
    thanks for the quick reply! hopefully thats the case and not another faulty pump! + removing the front end again!
  4. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,434
    570
    Not necessarily - it could be a number of different things
    Check your fuse box (F8 in particular) and if you can get on vagcom, get it checked out
    I got the infamous V157 fault which resulted in me replacing the throttle body which resolved the problem!
    The Econ light staying on is just like "safe mode" for the climate control
  5. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    65
    Have a read of the thread in my sig please mate. Then can you post a thread in the air con forum if you have any further questions. I check it everyday or so. :thumbsup:
