Another coding question
tuffy May 22, 2013
  1. tuffy
    tuffy Member
    314
    13
    Ok guys
    A fellow forum member was kind enough to come to my home with his vcds to code in my rns-e for me..... before we coded it everything worked fine, apart from the nav displaying in the colour dis (which now works perfectly after coding)
    But unfortunately the factory bluetooth that was picking up my phone before we coded the rns-e, is no longer working, when i scan for devices on the phone it says...'make sure Audi uhv is turned on and in range'
    Is this a coding error? or something more simple?
    if a coding issue, could someone give us the correct coding please before i trawl the net
    gen.heinz guderian likes this.
  2. matthew999
    matthew999 Member
    155
    Hi Tuffy
    Did you code channel 77 to 001xxxx, I think this is needed for Bluetooth, might be wrong but I have recently coded my Rnse and Bluetooth works. Might be an idea to post all the codes you changed so the more knowledgable can comment
    Matt
  3. tuffy
    tuffy Member
    314
    13
    Thanks Matt
    Sorry but I really don't know what the other codes were we entered. So it would appear its a coding issue??
  4. matthew999
    matthew999 Member
    155
    Oh dear, its good practise to note down codes before and after u start changing numbers, one to remember for the future ;-) Speak to the person who did it maybe he will have a better idea if he adjusted channel 77 and anything else he changed.
  5. rizzini7
    rizzini7 Active Member VCDS Map User
    983
    156
    43
    Try Danny, he might still have all the codes on his pc if you're lucky.
  6. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Wrote all the codes down before hand also saved first scan.
  7. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
  8. tuffy
    tuffy Member
    314
    13
    Thanks. What is your definition of a new style mfsw Dave ??
  9. PetrolDave
    1,559
    85
    As the Ross-Tech page says - one with rollers as well as buttons.
  10. matthew999
    matthew999 Member
    155
    thanks for that i think mine was coded stlightly wrong 0011622 instead of 0011822, another one to add to the todo list of coding
    cheers
    matt
  11. gen.heinz guderian
    1,346
    126
    Ok BT recoded but still has trouble connecting and dropping out intermittently ,telephone was 001622 now is 0011822. BT reset to default 1234 .
  12. PetrolDave
    1,559
    85
    What phone do you have?
    And what BT module version do you have?
    Some phones are notorious for poorly implementing the Bluetooth software stack, which makes their BT connection unreliable with some devices.
  13. gen.heinz guderian
    1,346
    126
    No idea what bt module version it is . It worked perfectly well before rnse was coded now is being a mare
  14. tuffy
    tuffy Member
    314
    13
    Its a iphone 4 Dave, No idea on BT version though. The car is a 2006 if that helps
  15. PetrolDave
    1,559
    85
    I've heard of some people having problems with iPhone when they have an early version of the Audi BT module - so that might be your problem.
    I've got an iPhone 5 and an M version module and don't have any problem.
