Another 8L Track Car - Lets get ready to 'Ruuuuuuuumble'!
Welly Oct 22, 2012
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Ok, the suggested colour scheme.... No. But the name? Fo sho!!
  2. Sam_
    Sam_ Down under
    3,035
    480
    Phew. Just keep it black and *maybe* chuck some dark wheels on it? Or better yet, just make it work good ;)
  3. Welly
    10,696
    127
    Ill try... I have a mental note not to use different compression ratio pistons or anything else from left field this time....
    Although that did work out well to be fair which is astounding!
  4. Prawn
    11,373
    3,242
    First there was Bumble,
    Who's fate took a Tumble,
    Then along came the Rumble,
    Which made poor Mel Mumble,
    but soon she'd be Humble,
    When the opposition crumble,
    At the mere sight of Rumble!
    MIGGZ likes this.
  5. Prawn
    11,373
    3,242
    definitely not bored at work.
    Honest
  6. Welly
    10,696
    127
    Prawn. WTF are you on? :)
    s3clarke likes this.
  7. Prawn
    11,373
    3,242
    I have NO idea, I'm 150 miles from home, stuck at work until some time next week, wanting to go home and drive my car some more so I can put enough miles on it to attend the B5 RR day.
    I'm awfully proud of your choice to name it Rumble, so many excellent rhyming words :)
  8. superkarl
    superkarl MAN OF STEEL
    9,374
    2,370
    lol
  9. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    Rumble grumble around the gumbal while dumble bumbled past.
  10. Welly
    10,696
    127
    Anyway.... :whistle2:
    The turbo has arrived. Well, the turbo and manifold have. Sadly they didn't remember the external wastegate - however 2 out of 3 isn't bad.
    Turbo - initial impressions? Massive. Much bigger than expected. Now have my concerns about physical fitment behind the engine. Anyway, that remains to be seen. Housings look good, comp wheel is pretty sizeable, as is the turbine.
    V band outlet is just a Garrett 5 bolt adapter which is handy. It is also internally gated with a 1 bar actuator. Wastegate channel is small and would almost certainly creep is it were used.
    Manifold looks pretty good actually, typically Chinese though. 4 port merge collector should flow pretty good and the runners aren't exactly long which should help keep lag down.
    Has come with a V band to match the housing, and a clamp. All the gaskets and bolts as well. On the whole, not bad for 320 sheets. However that is very much dependent on how long the turbo lasts!
    Some photos:
  11. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    Awesome!
    I have left over bits you can have dude,
    Pretty sure I never picked up that box of 312 parts, if I did I still have it somewhere which is a full front set up and discs.
    B5 Rs4 front brakes, complete set, not that they'll fit easily.
    I also have a pair of Corbeau bucket seats knocking about with crappy subframes that you can have on the cheap bud :)
  12. Jason.s
    Jason.s Active Member
    2,879
    348
    Going to get Bill to check over the manifold and beef it up where its needed or just going to sling it on and see what happens?
  13. Welly
    10,696
    127
    God knows where that box of 312 bits is dude, but thats a very good point. I forgot all about them. Will ask the olds where they stashed them!
    Those seats sound good - give me a call if you get 5 later on.
    Thanks Dane, much love :)
  14. Welly
    10,696
    127
    I am going to bolt it on as is and see what happens basically. I want to know how well one of these kits as is will operate...
  15. Welly
    10,696
    127
    OK, more photos today.
    Mock fitment of the turbo and manifold. In typical Chinese style, the head flange isn't flat... Fortunately I know someone who knows someone who has a REALLY big grinding wheel that can sort that out.
    The combination of the turbo and manifold is large though... fit is going to be tight. Very tight.
    10 inches clearance required behind the engine... Hmmm. The Actuator which is fitted here won't be on there fortunately giving more room.
    Thoughts at this point - the turbo is absolutely 100000% going to need supporting from beneath. The thing weighs a ton and there is no way that manifold will hold that thing up for long under duress without cracking.
    The manifold also needs skimming flat, and trimming along the top to make a snug fit to the head.
    To be fair, the turbo looks 'something' around GT3071 size. Far larger than a) I wanted and b) anticipated. But bugger it, it's here now!
    The way this turbo is going to be fitted is this:
    The V Band turbine housing is sh*te. Too small, and has the wastegate penny valve built into it for some reason. That's being removed as it's only a bolt on jobber. You can see it below, bolted to the housing:
    That's going to be binned. End of. The hole for the internal wastegate channel will then be welded up using a penny washer or something along those lines.
    Bill somehow knew where I could get a flange to use for the downpipe which mates to the bolt pattern so the downpipe, et voila. Hot side sorted.
    Actuator need removed and the housing needs clocking to suit. After that all I need is a working engine to bolt it to.... yay!
    So, got to work yesterday evening sorting the turbo out as above.
    V Band adapter removed - no need to weld up the wastegate channel - a finger seems to work well...
    Inside the comp housing:
    The comp wheel in all it's glory...
    Put it back together clocked correctly, with the actuator removed and the Turbine ready for a downpipe to be made .... yay :).
    Those who aren't friends of mine on Facebook may not have seen me scrabbling for change for some JOM coilovers...
    £135 odd quid which isn't far off. Coilovers will be ordered today.
    External wastegate also turned up today:
    Small - it is not. Has come with all appropriate flanges and gaskets etc. On the whole, for £320 delivered this stuff really isn't bad. OK, it needs a bit of work, and the turbo is a bit suspect, but lets be fair.... it looks good. lol
    Engine work begins tomorrow....
    StaceyS3 likes this.
  16. Yohan87
    Yohan87 Member
    426
    12
    Looking forward to this. I'm also slightly scared and it's not my money!
  17. superkarl
    9,374
    2,370
    turbo getting checked by dan?
    or **** it?
  18. Welly
    10,696
    127
    I've talked with Dan and he has suggested some suitable upgrades for it... BUT, I've decided just to whap this one straight on the genuinely test the out of the box reliability. That was sort of one of the points of the exercise.
    I am planning to buy another identical turbo and send that one down to Dan. He can work his magico and then it will be my spare.
  19. superkarl
    9,374
    2,370
    good plan.
    i hope this suprises everybody!
  20. coatesy
    coatesy poking badgers with spoons
    1,920
    280
    are you going to clock the housing so it points upwards or just try fit it as it is, looks like it will be a tight squeeze good stuff dude! you crazy fecker
    EDIT: i actually read what you had put in stead of been boss eyed and only skim reading. you already are clocking it, Doh!
  21. Paradox1
    Paradox1 Active Member
    1,833
    88
    Ffs pay attention to detail....
    I think all that hybrid powers gone to your brain.....I'm not jealous at al :)
  22. coatesy
    1,920
    280
    i know im sorry, it doesn't help that im slyly sat on asn when i should be working lol
    :racer: ha yeah the power does go to my head..
  23. Prawn
    11,373
    3,242
    Welly that's massive!
    It almost looks like it was designed to be mounted US style the other way round and effectively sit as a top mount!
  24. Reesy
    Reesy Well-Known Member VCDS Map User
    3,639
    148
    Whatever floats your boat.
    That turbo is big though, should power the new a3 track car to victory in the battle between you and Prawn. Just needs some Brembo's to stop it the other end..
    What is happening with the engine in the car at the moment, is it completely dead or salvageable?
  25. Prawn
    11,373
    3,242
    As if :laugh: I'm not giving up that easily.
  26. Prawn
    11,373
    3,242
  27. Andrew@A.L.D
    3,873
    609
    You missed out fuel pump
    I do have a spare one for sale if your interested? Its good for 600 bhp :eyebrows:
  28. Welly
    10,696
    127
    Not initially planning on using one on 440s, will check the OEM pump's output pressure.
    It's on the list of to do's, however not on the initial build.
    I did miss off AFR gauge though.
  29. Welly
    10,696
    127
    But how much?
  30. Welly
    10,696
    127
    To be fair, this is beginning to feel more like a team effort as the days go on Prawny-ma-bob.
  31. <tuffty/>
    20,847
    3,687
    Yep... you spend the money and we tell you where you went wrong :)
    ...typically in that order...
  32. Prawn
    11,373
    3,242
    I just keep finding track car bargains everywhere, or spare parts in my garage that I wont use :)
    Will keep my eyes peeled for anything on your list and post them in here.
    have PM'd martin for you about those seats.
  33. Welly
    10,696
    127
    I am insulted. It doesn't normally go THAT wrong.
  34. Welly
    10,696
    127
    :wub:
  35. Andrew@A.L.D
    3,873
    609
  36. Welly
    10,696
    127
  37. 666markyboy
    666markyboy Well-Known Member
    1,201
    49
    See if you can find him an LSD i think he's going to need one
  38. coatesy
    1,920
    280
    he should also find me, one a cheap one :D preferable if its stuck on a new gear box as well ...
  39. Prawn
    11,373
    3,242
    seats are no long available Welly :( Martin couldn't get hold of the seats he wanted so has ended up fitting these.
    Sorry mate, back to Danes forzas instead!
  40. Sam_
    Sam_ Down under
    3,035
    480
