Another 8L Track Car - Lets get ready to 'Ruuuuuuuumble'!
Welly Oct 22, 2012
  1. Sam_
    Sam_ Down under
    3,037
    480
    Fair play. He is doing it on a budget though :) A set of brembos or R32 brakes (which you hate I know) would blow that out a fair bit. Unless he gets a bargain?
    How long did he last on 312s with 450bhp? :)
  2. Prawn
    11,441
    3,335
    Too long to legally still be alive, and I went past him easily at Combe with just 200bhp, so it's clearly all down to the brakes :laugh:
    Look forward to seeing Wellyboots in a well prepared FWD A3 though, should be good fun at ADI next year!
  3. turnstyle
    turnstyle Member
    91
    I've always looked at cheap turbos and used the saying: "buy cheap, buy twice"
    But to be honest never thought of looking up project builds.
    I honestly didnt think they would hold up to much abuse. Although, for my money, id probably still stick with the bigger names in the business as my car is a daily grind.
    Look forward to seeing the results anyway.
  4. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    R32 Brakes are not a good idea. £150 a disc iirc, not ideal for a track car!
  5. Reesy
    3,640
    148
    Still not quite sure on the cheap turbo set up, all very well having a drag car/ road car with one, but as Prawn found out when using the basic silicone, track puts a lot more strain on bits.
    Worth a look to be honest and for the price if it blows up as long as it doesn't do any damage, a blown turbo is good fun.
  6. Sam_
    Sam_ Down under
    3,037
    480
    For OEM yeah (as they are kinda floating/2 piece like some of the bigger Audis) but EBC and a few others do cheaper solid alternatives. Might be a bit heavy but as a budget upgrade, probably cheaper than Porsche/Brembo/LCR setups...
  7. Prawn
    11,441
    3,335
    here's an awesome thought for inspiration.....
    To match Bumbles power:weight ratio in full road going form, assuming 445bhp and 1450kg, a stripped out FWD A3 would only need 337bhp. Well within reach of a gt28.... :)
    Going to absolutely fly when it's done I'm sure!
  8. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Wow, came back to find a barrage of posts I had missed!!
    I'd like to point out that I'm going to 'start' with 312s and see how it goes - not going to be a perma solution but will be good for a start!
    Tyres are the other choice matter. At Combe that year Prawny I was using those Sunnys (never again) and to be fair that had an impact on cornering as well as braking. They were not good tyres for the day. It was a point and boot scenario...
  9. Welly
    10,696
    127
    So I bought the car...
    VGC inside and out to be fair. Full service, and has has a new engine in it's life too. Actual engine in the car is a genuine sub 100K lump - however it does have an APU code... meaning the head at least is from a Passat. Weird. Cant's be a whole APU lump as the APU has an external water pump I believe.
    Anywhoo, who cares.
    Went to see it at half 8 last night, 15 miles from home around twisty country lanes. Towed the A3 home (due to oil pressure issues - does start and drive) using the 1.9 Diesel 206 which struggled to say the very least (it's hilly round these parts).
    The other thing that really didn't help was the fact I let my lunatic brother drive the tow car. This is the man who regularly drives home with his trailer on, doing 90 and upwards... An interesting drive home. If scary.
    So... the car is home. Well sat on my mate's drive at the moment at least.
    I'll get some photos of the beast up shortly. Oh, and it's black Prawn, not Minge Blue.
  10. aragorn
    18,129
    763
    I'll be going with 312's on my budget track car too :p
    Get some proper race pads in there and good fluid and personally i dont think you'll be that far off.
    Given prawn runs 323's which are only marginally larger, i think the 312's can be made to work just fine.
    It would be a different story if Prawn regularly cooked the 323's and had to fit 350's to keep the temps under control, but thats not the case is it?
  11. Welly
    10,696
    127
    I had serious problems with the 312s on Bumble, but that was actually to do with one of the calipers being dodgy as it turns out...
    It's a suck it and see scenario with the 312s, if they don't work out - they don't work out.
  12. Sam_
    Sam_ Down under
    3,037
    480
    You got carriers mate or do you want me to send these ones?
  13. Welly
    10,696
    127
    Ummm, well if you wouldn't mind, that would be awesome. :).
    PM me and we can sort out logistics!
  14. Welly
    10,696
    127
    It's simply got to be done hasn't it! It would be blasphemy otherwise... :thumbsup:
  15. finesse
    finesse Active Member
    2,805
    Welly, have you considered the SEAT Ibiza Cupra , much better chassis compared to the 8L
  16. <tuffty/>
    20,990
    3,760
    in std form it isn't and takes a lot more work to get them handling right... Bill's Ibiza is wide tracked with adjustable caster/camber top mounts etc... these can be had cheaply but not as cheap as the A3 and Welly is on a budget... can get the Mk4 platform to handle better for much less than a Mk3 Ibiza...
  17. badger5
    9,421
    1,964
    I boiled 312's into oblivion when going round combe... in my mk4..
    maybe I drive harder ;)
  18. badger5
    9,421
    1,964
    Seriously?
  19. <tuffty/>
    20,990
    3,760
    Welly has gotten used to not having brakes before the Brembos on Bumble ;P
  20. Reesy
    3,640
    148
    Tuffty, he said Ibiza not Leon :whistle2:
    I think that 312's are a good starting point. If you can get as much weight out the car as possible, they are worth a shot. It depends whether you want to try and have the fastest track car going or whether you set yourself some sort of limit and stick to it..
    (Look out for a post next year where both me and Welly say that we have cooked the 312's again and they are sh!t)
  21. Westy
    Westy Well-Known Member
    17,443
    1,103
    312 discs with my Boxster callipers work well on mine for the road and an occasional track outing. I've never warped a disc with them and only noticed them very slightly fading away after a full days tracking last year at Bedford Autodrome. I believe that on a much lighter car like a stripped A3 you'll be fine.
  22. <tuffty/>
    20,990
    3,760
    LOL... good spot... damn my skim reading... will edit with more appropriate response...
    What Bill said still stands lol...
  23. superkarl
    superkarl MAN OF STEEL
    9,421
    2,381
    and the end of the day its a budget track car.
    who gives a **** wether he has 6 pots or single pot sliders, he hasnt said hes making the absolute ideal track car
    he wants it to stop, sort of, if it doesnt, he'l just go round corners faster. WIN :racer:
    destroying things is more fun anyway
  24. Westy
    17,443
    1,103
    StaceyS3 likes this.
  25. aragorn
    18,129
    763
    What was the spec of your Mk4 bill, compared with whats proposed here?
  26. Welly
    10,696
    127
  27. Welly
    10,696
    127
    Karlos, you know me MUCH better than I thought....
  28. Westy
    17,443
    1,103
    Finally! You've bought a car that isn't bright yellow ;)
  29. Welly
    10,696
    127
    I am considering painting the bonnet and roof and rear spoiler Imola yellow to have Bumble in reverse...
  30. Welly
    10,696
    127
  31. Paradox1
    Paradox1 Active Member
    1,833
    88
    Reversed bumble lol
  32. Westy
    17,443
    1,103
    I think it's like a bee that's flown into your windscreen as you've been hooning it down the motorway.
  33. Prawn
    11,441
    3,335
    Actually, my 323's are right on the limit of what they can take heat wise. I'm having to add cooling to them to keep them at their best.
    They're sh*t!
    R-kelly believed he could fly, but like you, he was wrong :laugh:
    the reason your 312's work better is because the porsche calipers can deal with the heat far better
    At the end of the day guys, what Bill and I say is right, speaking from experience, 312's are NOT up to track work.
    It's not the mechanical stopping power that's the issue, as kev says the percentage difference isn't massive between 312's and 323's, and the hydraulic power isn't that different either, but the thin 25mm discs, and nasty iron single pot calipers just cannot cope with the heat build up at all, and they fade and fail within a few laps.
    My 323's don't fade power wise, but they run ULTRA hot as can be seen from the colour of the discs, and pedal feel deteriorates towards the end of a 15 minute session. I'm mid way through adding brake cooling ducts to try and solve this without the expense of 2 piece 330mm discs.
    To put it another way, if you're finding 312's with single pot calipers are OK for track use, then you're probably pretty damn slow.
    Welly is a keen driver as we all know, 312's woudln't last 2 laps of Combe with him driving regardless of pad choice.
  34. badger5
    9,421
    1,964
    Hybrid IHI, ~350-390bhp
    some pix of it from its magazine shootout back in 2005
  35. Prawn
    11,441
    3,335
    Oh, and it's great to see you back in a Proper car Wellyboots. Most impressed :)
  36. badger5
    9,421
    1,964
    lmao - that should upset the armchair internet experts reading this...
    100% with ya prawny
  37. coatesy
    coatesy poking badgers with spoons
    1,920
    280
    Iv never been on a race track before but I wouldn't use 312 brakes on the track, they get scary at times when playing rally drivers on empty roads
  38. Sam_
    Sam_ Down under
    3,037
    480
    Suck it and see? After all, it's meant to be a budget track car isn't it? Might not be ideal for the track experts out there but I don't think, from what I can gather, that's what it's all about. Think of it as a MVP :)
  39. Welly
    10,696
    127
    Budget required 312mms as a starting point. Are they the best? No. But for now they will bloody well have to do! lol.
    Brembos are the future plan, a very good upgrade on Bumble and more than worth it. Sadly, that's 500 I don't have at the moment. And I also have an engine to build.
    First we make go fast. Then we worry about stopping and cornering :thumbsup:
  40. Welly
    10,696
    127
    I don't have to listen to these wild allegations!!
