Amping the front door speakers
RobMorris Dec 1, 2011
  1. RobMorris
    RobMorris Member
    539
    10
    Chaps
    Is it easy enough to run speaker wire so I can amp uo the front speakers of a A3 8P 3dr?
    Is there a 'how to'?
  2. AndyMac
    9,832
    45
    Just pick up the feed from the existing wiring. There's no way through the door pillars as all the wires are on a connector which is impossible to get to
  3. RobMorris
    RobMorris Member
    539
    10
    Understood, I guess just locate the loom from inside the cabin close to where it goes through the rubber into the door and do a 'cut and shut'?
  4. AndyMac
    9,832
    45
    Do you have Bose or non Bose?
    for non Bose it's easy, as you can pick up the feeds from the connector at the HU. No cutting required. Depends if you are upgrading the front speakers as well (no real point doing it without as the stock speakers are garbage) as the tweeters are in the A pillars rather than the doors so you need to separate the wiring if using components with a separate crossover
  5. RobMorris
    RobMorris Member
    539
    10
    I have non bose.
    Good call grabbing it from the HU.
    Im running SPL Dynamics SD6.2 in the front doors and wiring them up to an amp in the boot..
  6. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    Would amping the front speakers make a huge difference ?
  7. beanoir
    beanoir Large Member
    2,171
    30
    Yes, the front speakers are the most important speakers in the system and amping them and using good speakers makes a big difference.
  8. AndyMac
    9,832
    45
    Absolutely, but you do need both - amping the stock speakers doesn't really help as they are shockingly poor.
    If you have non Bose then just buy a male-female ISO speaker lead (£4.99 from maplins) and then plug one end into the Audi front speaker harness, the other end into the HU then chop the 2 pairs of outside wires and connect the new speaker cable to the HU side observing the correct polarities. If your aftermarket HU has flying leads for the speaker outputs then you don't need to do this, but many just have an 8 pin ISO plug, so this avoids chopping the Audi loom.
