Amp Power Lead......
Mackers Oct 29, 2011
  1. Mackers
    Mackers Member
    291
    Hi all, i have an Audi A4 (B5 2.5Tdi)
    how or where do i get the power leads from the battery into the car, so i can wire my 3amplifiers up.
    Many Thanks
    Wayne.
  2. AndyMac
    9,832
    46
    Through the ECU cover is the easiest method. It drops down into the drivers footwell.
  3. Mackers
    Mackers Member
    291
    ideal,,, quickest reply i ever had on here too :D :D :D
    next question... can i run 2x 4guage cables that way too, as i'm running 2x 1800W amps for the amps
    and also a 1300W amp for the door speakers.
    Thanks Again.
  4. Broken Byzan
    13,237
    465
    Yep, I ran 0 WG down mine no problems
  5. Mackers
    Mackers Member
    291
    ideal, many thanks.... was lifting the sill panels to gain access under the carpet for the leads a pain in the **** to do too, as i don't want to pull too hard, or is there a "trick" to taking them off.
    can't wait to hear my 2x kicker solobarics running again...... as i had a MX5 (dream, affordable car) for the last 3yrs and had just 1 in the boot, which is a separate compartment and it was somewhat muffled. :D :D
  6. AndyMac
    9,832
    46
    Brute force is needed, but you start with the small panel in the footwell as they are all interlinked, but you do have to be quite aggressive
  7. Mackers
    Mackers Member
    291
    cables routed and amps and subs and power caps fitted :D :D OMG i missed my SQUARE KICKERS!!!! :p :p me likes
    3600Watts Of Pure BASS!! :D
