Amp in boot RCA lead question
imported_kenloen Apr 20, 2005
  1. imported_kenloen
    imported_kenloen Guest
    i already have a CD changer and am thinking of fitting a 4channel Amp in the boot. Where can i run the RCA leads? they wont fit under the kick plates and i would need to keep the Amp power lead and signal cables seperate .. any ideas
  2. QuantumJohn
    QuantumJohn Member
    142
    I run my power cables down the drivers side of the car and the RCA leads down the passenger side. Both lots of cables are housed under the plastic inner sill trims - just inside the rubber door seals. They are held on by clips and can be carefully prised off.
    John
  3. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Yeah power down drivers side, as the easiest way through the bulkhead is through the ECU housing on the drivers side, saves having to route across the dash.
  4. i have also done as said above.
