amk S3 fault codes please help :(
tonks s3 Jul 1, 2012
  1. tonks s3
    tonks s3 Member
    33
    Hello there I'm fairly new to the forum and to Audi so any help would be amazing, one of my mates plugged into my car the other weak due to it throughing up the engine management light,esp and abs my front left wheel bearing is going to be replaced which could be 1 or 2 faults cleared, but for the others I'm very confused!.
    Engine codes faults
    17544
    16395
    18010
    17947
    00283
    65535
    01316
    if anyone could help with some solutions and maybe pictures with these would be much appreciated :) cheers tonks
  2. <tuffty/>
    21,689
    4,121
    If you could either post up the VCDS output or have a look here (Category:Fault Codes - Ross-Tech Wiki) first to get the descriptions that would help mate...
    The codes by themselves don't mean alot...
    For example... 17544 is:
    17544/P1136/004406 - Ross-Tech Wiki
    This indicates a big vacuum leak...
    Have a look at the rest on the wiki and post up the ones you are not sure about...
  3. tonks s3
    tonks s3 Member
    33
    Ohh thanks for that tuffty great help! I've done n249 bypass and I am running a 008p anywhere you would look for the leak?
  4. <tuffty/>
    21,689
    4,121
    Most leaks are in the pipes under the inlet manifold...
  5. tonks s3
    tonks s3 Member
    33
    Cheers dude!
