A friend of mine has a 2001 audi s3 and when he got it he was told that it was a bam engine and in the v5 it says bam but when u look at the engine stamp it say amk why would this be? It hasnt had a engine change so we can rule that out.
What's the actual difference between AMK and BAM?
Is APY only whitout variable valve timing?
Wasent aware of the lack of VVT i was always told the APY had a mechanical system wheras the other two have an Electro-Hydraulic type?APY has no VVT, no EGT, no wideband lambda
Fair Enough, The more you knowBoth chain tensioner units are hydraulic (Oil pressure) but APY is fixed, AMK/BAM has a valve/solenoid setup to alter inlet cam position
