Ambient Temperature Display
justandy Jul 21, 2008
  1. justandy
    justandy Not an S3 owner!
    30
    My bargain basement? (A3 special edition - not SE) does not have the outside temp display switched on, I know it's there, under the clock. (no DIS).
    Does anyone know if this can be switched on with VAG-COM, I spoke to the stealers and they are unsure, they think it uses the same sensor that the A/C uses to sense below 5C and disable the compressor.
    They are going to have a go on Thusday FOC! Maybe I should get the door warning/puddle lights switched on to.
    Andy
    ***UPDATE***
    Top marks to Simon and Darren at Stafford Audi, they tried for over an hour yesterday and had no luck, they put in a request to Audi Tech and got a reply from Germany.....
    Seems there is a hidden channel (20) and this is coded to (1) to switch on the display. So off to stafford I went, again, and 2 minutes later success!
    They would not give me a copy of the tech report so this is only word of mouth, shame really.
    I don't know if this works for cars without aircon, you may not have all of the parts fitted, but if you have aircon it certainly works.
    Andy
  2. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    As far as I know if you don't have the full DIS you can't enable the outside temperature guage.
    Although I have seen somewhere where you can enable the DIS for cars with DSG. I'll try to dig out the link.
  3. justandy
    30
    My 04 A3 didn't have full DIS but still had ambient temp display, don't have DSG.
    Maybe it's a lost cause, it was, I think an option from new, buried somewhere amongst the specs, but it was never in the configurator.
  4. nhowroyd
    nhowroyd Member
    128
    My car is DSG but I didn't know it was DIS as I have no controls for it..... If it is possible to activate the DIS I would be happy...
  5. justandy
    30
    There is a thread on here somewhere that tells you how to activate the DIS on DSG cars, it involves fitting a new indicator stalk with buttons to use the DIS and some re coding with VAG-COM.
    The local dealer tried for an hour to activate my ambient temp display but with no luck, they did however switch on my door warning lights, parts ordered for this mod thanks to Robin.
  6. MarcQuinlivan
    2,539
    Found this over on vortex;
    You can enable the distance to empty bit without buying a new wiper stalk, but you'll need the new stalk to allow you to scroll through the other menus - trip distance, mpg, etc.
  7. justandy
    30
    Bump!
    see edited firs post ;-)
  8. MarcQuinlivan
    2,539
    I'll take a look at VAGCOM later and see if I can figure out what that setting is.
  9. phil_w
    phil_w Active Member VCDS Map User Audi A4 Audi Avant Owner Group S-line owners group Team Brill Red
    606
    58
    Many thanks for that post - worked like a charm! Saves me buying parts and cable only to find the sensor already in place!!!
  10. MrTea
    MrTea Member
    53
    Interesting post... I had a feeling all this stuff could be activated fairly easy on the basic DSG DIS although I'm not sure if it would work for my 2005 edition and whether I've got the skills to do it...
    ..I removed the dashboard on my old car and it was never quite the same again :keule::lmfao:
  11. carbon
    carbon New Member
    hi,any joy with the codes for all the modes-trip,distance,mpg.
    cheers
  12. sicky
    sicky New Member
    hello
    my car's in getting serviced this week - if i want them to turn on the ambient temp display...how do i explain to them what i want/how to do it etc? i'm expecting them to say it can't be done/they don't know how
    can anybody give me the pointers/step-by-steps that i'd need please?
  13. epirb
    epirb New Member
    My new to me '05 A3 appears to be a very basic spec as well with no DIS, no ambient temperature display and no air conditioning! Very basic I know but I still love it. Anyway, is there an easy way to find out if it has the temperature sensor fitted? Can you see it or any of the wires without taking the bumper off? I know I could just try coding it and seeing if it comes on but I don't have a cable yet.
    Cheers.
  14. epirb
    epirb New Member
    Anyone able to help?
    Also without going off topic, are there any threads for these bargain basement models? I'm interested in doing a double din conversion but can't find any guides for models with the manual heating control/ no climate control.
    Any help is much appreciated.
  15. harvz
    harvz Member
    72
    Hi i know this is old thread but im just confused, to enable ambient temp must i install the yellow wire? or is it just coding "hidden channel (20) and this is coded to (1) to switch on the display"? I have dis enabled using vcds and am going to install cruise control stalk and wiper stalk for controls with trip comp
  16. addyblanch
    addyblanch New Member
    Hi all,
    After some intensive searching I've found out how to do this.
    From VCDS main menu:
    Select Control Module
    17 - Instruments
    10 - Adaptation
    Change new value to 111
    Boom Ambient Temp Display!
  17. addyblanch
    Sorry now i've done mine thought i'd add a bit more info - You have to select the option from the drop down menu at the top for ambient temp and the new value actually needs to be changed from 2 to 1.
    Hope this is helpful to someone!
    leegsi likes this.
