Am i been thick?washer bottle alarm,2 wires to cancel ? i've check past threads..HELP
holmefield Jun 24, 2012
  1. holmefield
    holmefield Member
    383
    9
    Hi i did the retro-fit DIS to my 54 plate b6 sport awhile ago and got the washer bottle alarm as expected afterwards now i've lived with it for awhile but its now doing my head in and i need to get rid of it.
    I've checked through past threads as to how to get rid of it, but im confussed as its all a bit tech-speak to me.So can anybody give me a simple answer to these two questions please.
    POINT 1....
    You need to run two wires, i get that, one to earth ( by earth i take it somewhere under the bonnet ? )
    WHERE DOES THE WIRE START ?? ( somewhere on the washer bottle ?)
    POINT 2....
    The wire that runs into the car, where does it run to, is it behind the dashboard clocks? ( how the hell do you get them out ? ) or is it this pin that i keep reading about? ( wheres the pin, and how do i get @ it please? )
    CAN SOMEBODY HELP ME, im sure its easy to fix i just need some answers....Cheers
  2. chasdrury
    chasdrury Member
    360
    17
    2 options - to disale the alarm you run 1 wire from the dashboard pin to ground (behind the kick plate by drivers rigt leg). Not sure which pin, that's on the how to's.
    2nd option is if you want it to work,you can buy the sensor, put it in the washe bottle then run 2 wires - 1 from the pin in the dash and 1 to ground then you have the sensor.
  3. holmefield
    holmefield Member
    383
    9
    I've looked @ the how to's and it gets very techy for me to understand, which pin is it behind the kick plate ( by kick plate is that down on the floor near the acceratot pedal.
    Sorry if i sound thick i just not very clued up with electric stuff its my dad that will be doing it and im just trying to get all the info for him...
  4. fourcircle
    fourcircle nj
    927
    27
  5. fourcircle
    fourcircle nj
    927
    27
    haha. I just saw the date on the previous post. I accidentally found this thread while looking for instructions to change a washer fluid bottle :)
