Alternator or Battery?
SunnyG Jul 15, 2012
  1. SunnyG
    SunnyG Member
    41
    Hi there, just got me a PD130 A3, car has a strange issue has to be push started otherwise doesn't start can then be driven around but lets say you drive it for 20mins the car doesn't start again. Could this be battery issue or alternator?
  2. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,662
    116
    Sounds like battery isnt holding its charge.
  3. aragorn
    18,036
    724
    stick a voltmeter across the battery with the engine off, and again with the engine running.
  4. SunnyG
    SunnyG Member
    41
    What should I be looking for on the voltmeter? I just want to be sure to be honest.
  5. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    13.9 or above when running
  6. SunnyG
    SunnyG Member
    41
    So if its below it means? sorry about being such a noob
  7. Ste_Nova
    1,223
    47
    alt not providing charge
  8. SunnyG
    SunnyG Member
    41
    okay thanks so if i see 13.9+ its the battery for sure?
  9. aragorn
    18,036
    724
    could also be the starter, hence why i said check with the car off too
  10. SunnyG
    SunnyG Member
    41
    okay thank you but i guess if its lower than 13.9 running that eliminates the alternator? Thanks for all the help
  11. aragorn
    18,036
    724
    if its at or above 13.9 then the alternator is fine.
    With the car off i'd expect to see 12.6v or so from a healthy battery.
  12. SunnyG
    SunnyG Member
    41
    thanks for all the help
  13. Squirrelofdoom
    Squirrelofdoom Member
    671
    23
    TO be hoenst, if your alternator was gone, you couldn't get a mile down the road before your 12V system shutting off :) I think you can safely assume your alternator is fine
