ALLROAD INTO AN A4
brownie 25 Apr 13, 2010
  1. brownie 25
    brownie 25 Member
    383
    9
    hi lads.
    would anyone know is there much hassle in putting a engine from an allroad 2.5 tdi v6 into a a4 2.5tdi v6.
    are they exactly the same engine,thy both have same engine code (ake).
    tks.
  2. adamss24
    adamss24 Well-Known Member
    4,552
    392
    They are the same base engines bar a few differences... The a4 will have twin intercooler/the allroad will have front mounted intercooler, the intake pipe is a different shape compared with the a4 and the maps in the ECU are different...
  3. brownie 25
    brownie 25 Member
    383
    9
    does that mean that i will have to take the ecu from the allroad or would the original one need to be remapped in the a4
  4. brownie 25
    brownie 25 Member
    383
    9
    anyone
  5. Mudplugger
    Mudplugger Member
    98
    I'm no expert on this and I may be wrong, but I've played around with engines & ECUs from the Peugeot Citroen range some years back:
    It didn't take me long to realise that the 1.9i petrol engine in the ZX Volcane (hot-hatch) was expensive, and its ECU (mounted towards the front and easily damaged in a shunt) was even more expensive (I was quoted £200 secondhand, and even then only when one came into the yard). However the Peugeot 406 SRi (a popular rep-mobile) also had a similar 1.9i petrol engine and its ECU was a mere £10 secondhand with about 50 to choose from.
    Following a shunt in my Citroen rally car which the engine survived but the ECU didn't, I quickly bought one from a Peugeot breaker and stuck it in. The result was a slightly different power and torque curve, which I could feel whilst driving, but everything ran fine and I never did bother to change it again!
    Based on this experience therefore I'd say that if both engines are VAG AKE there's a good chance they use similar sensors and ancilliaries, so you can probably pick whichever ECU you would prefer the characteristics of and drive using that. In this sense you are perhaps doing very little different from the company that charges you money to burn a different program onto your existing ECU, except that you're choosing a different factory program (and probably saving money too).
    This is just my opinion however, based on experience with a different maker's petrol engines, so it's entirely your risk and don't blame me if it all goes horribly wrong and costs lots to fix!
