Alloys Question!! 19" on S3!
HSerce Nov 28, 2009
  1. HSerce
    HSerce Member
    72
    hi, sorry but i did search but didnt find the answer to my question..
    my question is that i just brought myself a set of 19" kahn RSV alloys for my 2007 S3, and when i go over speed hump's it rub's..?
    There 8.5J 19" Kahn RSV with 235/35/19 rubber on them...??
    What do i need to do so they dont rub?
  2. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    I got 225 tires to reduce the width , The tire wall slopes back so it doesnt rub .
    N8kow on here should know , i think he runs 215 tires so he's your man to speak to he know wheels, offsets ,tires etc .....
  3. Lee_R
    Lee_R Active Member
    2,499
    12
    offset is crucial, what offset are the kahns?
  4. 10blazin
    3,301
    my offset is 45 and would deffo rub with 235 tires on
  5. david_phillips95
    david_phillips95 Member VCDS Map User
    504
    where is the rubbing coming from? you can remove a screw from the rear wheel well and this can help.
  6. L2DFP
    L2DFP New Member
    Im running 19" Kahn RSV's with 235/35/19 tyres and absolutely no rubbing issues, admittedly its not on an s3 so the suspension is a little higher!
    Im going to change to 225 tyres next as the road noise is annoyingly loud.
  7. N8
    17,163
    718
    225s will be fine, what offset are they?
  8. mitch78
    mitch78 Active Member
    2,350
    I had 235s on mine with a 42 offset and no rubbing (but I had removed the screw). In fact, they're the black wheels in the pic in my sig.
  9. chagrin
    chagrin New Member
    21
    Where is the screw in the rear wheel well? I thought the screw is only in the front wheel well?
    I just got my KW v3's installed and I'm getting rubbing on the rears in some instances.
    I'm running 235/35/19 tyres on Oettinger RXX 19X8.5 +50 offset, and I'm getting rubbing on the rears with passengers in the back.
    Would appreciate if anyone can point me in the right direction with regards to this screw. Would like to see if this is the cause.
  10. N8
    17,163
    718
    225s to be safe people.
  11. zaeem
    zaeem Member
    99
    52
    i am having the exact same problem with my s3 sportback even tho i am running 225/35/19 my offset is 48. i think its definitely the screw. Where is this screw?
  12. mitch78
    2,350
  13. N8
    17,163
    718
    :lmfao: Where?
  14. mitch78
    2,350
    I thought that was easier than trying to explain to someone. :laugh:
  15. zaeem
    zaeem Member
    99
    52
    so by removing the screw the bumper wont fall off
  16. Boydie
    Boydie Boycie VCDS Map User
    3,283
    394
    If it the screw at the top of the bumper at about 2 o'clock looking face on at the arch then no, it wont fall off
    I took mine out when I put kumho's on my A3 - the tyre wall was slightly different to my previous tyres and would rub a bit if hitting a pothole or bump too hard
    no issues though in my s3 and its lowered 40mm on h&r springs and 19" bbs ch
  17. N8
    17,163
    718
    I (well, Matt & Me) took mine off on saturday to fit my new valance, no that one screw won't make the bumper fall off, come on, audi's have better build quality than that! :wub:
    Boydie doesn't have any rubbing as he's running a high offset...
  18. Boydie
    3,283
    394
    Proper offset N8 lol :p
  19. HSerce
    HSerce Member
    72
    hi the offset is 45? i think.. but when i go into a pothole it rubs and over a speed hump fast again it hits..
    what shall i do?
  20. Boydie
    3,283
    394
    What brand are your tyres?
    As I had mentioned before, 2 different brands behaved differently when on my car due to the angle of the side wall.
    Try fitting some 5mm hubcentric wheel spacers and see if this cures the rubbing issues
    My old A3 was lowered to the tyre all round on coilovers and 19s and never had one rubbing issue.
  21. HSerce
    HSerce Member
    72
    well i had fedaral on backs and falkans on front and then it was always rubbing, changed them over now only when i go in a pot hole or on full load it rubs..
  22. chagrin
    chagrin New Member
    21
    Just back from the mechanic getting my KW v3's adjusted. Steering now feels really great and the car handles beautifully, but is a little too firm for my liking. With load, the rear wheels are STILL RUBBING!!! Found the culprit. It's not the screw that Mitch was pointing out but rather the lining in the wheel well. Going to get someone to heat it up, and get it plastered against the wheel well. Currently its rubbing against an area which is protruding.
    Will update if it is successful. Wish me luck. I hate going back and forth to the workshop when the problem is not resolved! :(
  23. N8
    17,163
    718
    Proper IRISH man offset yeh :laugh:
  24. ASHAL
    ASHAL New Member
    hi guys ,
    I have the same problem with my 2007 A3 2.0T FSI. Put on R8 -Replicas with 225/35/19 tyres with standard suspension and it rubs if I have two people in the back. What must I do ? Change springs ?
    Please help.
  25. HSerce
    HSerce Member
    72
    any help guys?? again 07 S3 235/35/19 rubber 8.5j 19" kahn rsv offset 45??? help!!
  26. chagrin
    chagrin New Member
    21
    sorry, can't help you yet mate.
    my issue is not totally resolved. under hard cornering, i'm still rubbing ...
