Alloy Wheels
roba4cab Sep 26, 2011
  1. roba4cab
    roba4cab New Member
    23
    Am i right in saying that alloys with an ET 54 will fit on my 2004 cab with wheel spacers?
  2. quattrojames
    14,050
    578
    They'll fit yes, but you'll need a minimum of 10mm spacers for it to look half sensible.
  3. way318
    way318 Active Member
    309
    32
    What offset can you fit to a B6 with/without spacers??
  4. mikeh126
    mikeh126 Member
    152
    I'm running 18" x 8.0J, with an offset of ET42, with 10mm spacers, making them ET32. Wouldn't want to go any lower - that's about the limit on a 'standard' B6.
    Not sure about the S4 - maybe it has wider arches to accommodate a smaller offset.
  5. quattrojames
    14,050
    578
    I agree, 32-35 is the lowest ET for me, unless you like stretch/poke etc, but I'm not into all that.
    S4 has the same body as A4's.
    Sent from my BlackBerry 9700 using Tapatalk
  6. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Most of us are using spacer's, so don't be put off..
  7. way318
    309
    32
    Thanks for the info :icon_thumright:
    The reason I asked, was that I had seen a set of 16" alloys which would of been ok for winter but they had a offset of ET31 so wasn't sure if they would fit or not.
  8. quattrojames
    14,050
    578
    ET 31 will probably be ok, as being 16's they're probably a 7.5j width?
  9. way318
    309
    32
    The info I got back from the guy selling them said they were 7Jx16H2 ET31.
  10. way318
    309
    32
    Does anyone know what alloy wheels this part number is for - 4F0601025N?
  11. paul20v
    paul20v Audi fanatic
    1,113
    Hi was running 8x18 et30 and they were still under the arches .
  12. way318
    309
    32
    I've seen a set of wheels which are 6j x 16 Et50 would these be ok on a B6?
