alloy wheel question
Ollie-B Jan 20, 2013
  1. Ollie-B
    Ollie-B Rockin' Shnit
    328
    I have bought some 8x18 et 32 alloys and was wondering what tyres fit this size rim and would this offset give it a wider or narrower stance? Would i need spacers to fill the arches?
  2. crazypainter
    crazypainter Member
    590
    wider or narrower than what? if you had 8x 18 with an ET of 45 they would sit further inwards than 8 x 18 with an ET of 32. Sounds like they will be fine and fill out to the arches just fine. I am not entirley sure the correct tyre width for those as I run slighly stretched tyres at 215 up front and 225 on the rear, so I think that 235 is what you would need but someone who knows will be along and input I am sure !
  3. munchkincoupe
    munchkincoupe Member
    948
    19
    Will give it a wider stance so no you won't need spacers but you may get some rubbing of the tyres on the arches on full lock depending on tyre size
    A lower number offset than your standard wheels moves the wheel out of the arch!
  4. Ollie-B
    328
    Offset sounds good to me, thanks lads. Just need the correct tyre size now :)
  5. quattrojames
    14,045
    570
    All A4's with 18" 8J wheels left the factory with 235 tyres. Some people fit 225's as they're cheaper, and some fit 215's if they like the stretched look. So it depends what you want.
  6. Ollie-B
    328
    Thanks mate, whats an ideal profile?
  7. dpbayly
    dpbayly Member
    391
    My wheels are 8x18 et35 so mine without spacers sat 3mm further in the arch than yours will fit mine also had 235/40 18 tyres fitted all round if your's is a quattro its best to run the same size tyre front and back to keep the rolling radius the same,
    Here's how they looked in the arches:
    Im now running the same wheels but with 20mm spacers rear and 15mm spacers front but i also changed the tyres to 225/40 18 to make it rubbing free, i took this route as i like the wider look.
    How it looks now in the arches:
  8. Ollie-B
    328
    looks smart as hell that mate, think al go 225/40 thanks alot boys
