Alloy wheel expert help needed
MTRL Jan 24, 2012
  1. MTRL
    MTRL Split Grill!
    459
    52
    I need a trained eye please:
    I brought a set of used genuine 18" RS4 Alloys, one turned out to be buckled so I sourced another from ebay.
    I assumed all genuine RS4 18" woud be the same.
    It arrived today and it doesn't match.
    (ignore the aparent size difference, car is on 225/40/18, new wheel is on 235/40/18. Alloys themselves match in diameter and width).
    The space between the sets of spokes is bigger.
    The finish is duller than the ones already on the car.
    Is one kind a replica? If so which kind?
    Shiz of ebay is 9 times out of 10 a massive let down!!!
    Ones I brought last week installed, ebay one next to it:
    Last weeks purchace:
    Ebay purchace:
    Ebay purchace has part numbers stamped around the hub:
    Last weeks purchase has the numbers stamped on the rear of the spokes (no photo)
    Can anyone shed some light please?
  2. Ads
    Ads License to drive
    8,230
    607
    I reckon the ones on your car are replicas, and the ebay one is genuine.
  3. *Müllërz
    *Müllërz REVOlutionary
    479
    n8's the don on these things
  4. Sheikh
    Sheikh Member
    654
    20
    Yeah the ones on your car look like reps... you can spot RS4 reps from a mile off. Although i could be wrong.
  5. Ads
    8,230
    607
    I'm sure the genuine ones have a slight lip that runs around the rim and your ebay one has it.
    The ones on your car don't.
    Also, look at the hole for the air valve. The hole for the wheel on your car looks slightly off-centre on the rim, whereas the ebay alloy looks dead centre:
  6. cwitcombe
    cwitcombe Member
    34
    Agree with this, RS4 originals have a lip around the edge.
  7. MTRL
    MTRL Split Grill!
    459
    52
    I see what you mean, its quite noticeable now you have pointed it out.
    I have spent a lot of money on the car recently so have no choice, its going to have to go on for now... with 225 tyre
    Will it cause a problem putting one odd wheel on there? weight difference?
    This is very disapointing I thought my first purchace was genuine.
  8. Ads
    8,230
    607
    The fact that they are reps probably explains why one was buckled.
    My guess is that the offset will be different on the genuine alloy.. i.e. the wheel will sit further in or out of the car than the other 3 wheels. Not ideal.
  9. crunchie
    crunchie Active Member
    880
    77
    Need to check the offset of the genuine one against the other 3 replicas also.
  10. MTRL
    MTRL Split Grill!
    459
    52
    How do I find out the offset?
  11. Ads
    8,230
    607
    Well the ebay one is ET43 (see your photo below):
    You'll have to take off one of the other wheels to see if they have the offset stamped on it too. Will be "ET##".
