Alloy Wheel Bolts?
imported_Rooney Sep 28, 2004
  1. imported_Rooney
    imported_Rooney Guest
    If I were to buy some Original Audi TT 18" RS4 look-alikes, Will the bolts from My standard 17" Avus Wheels fit them?
    or
    do i need to purcase new bolts to fit the 18"?
    Help please!
  2. Stepho
    Stepho Member
    444
    If you are purchasing aftermarket replica RSTT's they should come with new wheel bolts.
  3. imported_Rooney
    No they are originals off an audi TT, only single drilled not multi drilled like most replicas.
  4. Stepho
    Stepho Member
    444
    I've had two sets of replicas and niether were cross-drilled, but the answer to your origional question is the bolts from your Avus style alloys should fit no problem. A way to check however would be to remove one off wheel bolt and pop it in your RSTT wheel through the hole and pull the threaded end at the back of the wheel you should be able to feel if it is seated properly. /ubbthreads/images/graemlins/beerchug.gif
  5. L14MDP
    L14MDP Member
    33
    just got some original RS TT 18" wheels to replace my 17" Avus and used original bolts with no problem. /ubbthreads/images/graemlins/groovy.gif
