Alloy pedals and sat nav
stevey_boy Jun 8, 2008
  1. stevey_boy
    stevey_boy Member
    41
    can u get alloy pedals and dead pedal for the a4 (not sum off the crappy universal ones) and have u guys any pics?
    also is it possible to retro fit a indash sat nav unit into a 2002 a4 and if so is it a big job and more importantly how much would this sting me lol
  2. chasdrury
    chasdrury Member
    360
    17
    https://sslrelay.com/s74326199.onea...e=0010_RS4+pedal+rubber+set+=28RS4pedalset=29
    https://sslrelay.com/s74326199.onea...ipt?article=0015_RS4+dead+pedal+=28RS4dead=29
    Those are from an RS4, fit straight on (assuming a manual car) and are good quality.
    The sat nav, yes can be retrofitted. Which stereo is in your car now? The small (single DIN) cd player or the in dash 6 CD? If it's the former it's more work than the latter but done by many many people. http://www.navplus.us is probably the best place to find out about that one
    Chas
  3. stevey_boy
    stevey_boy Member
    41
    yea those pedals look spot on!! do they clip on on do they need drilling??
    my sterio is a single din cassette player :asskicking:
  4. Niknak
    Niknak Member
    867
    You have to heat the new ones with a hair dryer then slide them on, a little bit of a pain but look good when finished.
  5. Marc1
    Marc1 Member
    728
    Probably a daft question, but I take it you remove the current pedals rather than these sliding over the top like cheap covers?
  6. JohnboyC
    JohnboyC Member
    858
    13
    Ok...may sound a little old fartish.....but when I see those sort of alloy pedals I cannot help but think they belong on either the RS4 (for which they are intended).....or a chavved up Corsa, Nova or Saxo with big bore exhaust........
    The Audi RNS-e Sat Nav is a really nice integrated system.....and I have recently installed the OEM Audi Bluetooth as well...which is excellent !!!!
    You will have to replace the single DIN with a double DIN fixture (which fortunantly I did not have to do) ...but I installed the RNS-e Sat Nav & Bluetooth myself....got all the bits of E-bay (the German e-bay www.ebay.de is the best place to find bluetooth stuff). I got my RNS-e from E-bay (UK).....if you want any advice check out
    www.navplus.us which is great source of information....
    E-mail me if you want ANY advice on RNS-e installation....particularly Bluetooth wiring...
  7. Niknak
    Niknak Member
    867
    I would hardly say they look chavish
  8. NOLOGY
    NOLOGY AUDI OWNER
    101
    Has anyone ordered from this web site that chasdrury says? Are they reliable?
  9. chasdrury
    chasdrury Member
    360
    17
    Yes, they are reliable. www.vagparts.com
    Very well known and commended...
    Chas
  10. evilscotsman
    evilscotsman Space Cowboy
    1,350
    14
    You must be thinking of chromed plastic ripspeed types mate, (LOL) like the **** they sell at halfrauds and in max power :lmfao:
    Proper machined aluminum or stainless is beautiful, and why should only the S4 have nice pedals? Cos its fast??? :think:
  11. J7USS
    J7USS Shuddup Foooool!!
    3,737
    76
    Hmmmm I like them!
  12. jase0851
    jase0851 Member
    789
    ive had allsorts from vagparts nol mudflaps, rs4 start buttons, aero wipers, discs etc etc they are good but sometimes delivery takes a while if they dont have what you want they have to order it from germany. generally delivery is a week or 2
  13. Niknak
    Niknak Member
    867
    Nice aren't they!:sex:
  14. A3NDY L
    A3NDY L On the Drive or On The Redline
    55
    If there are enough of us interested would it be worth considering a group buy? See if we can get some sort of discount?
  15. coyote
    coyote Member
    217
    I would be interested in this.:thumbsup:
  16. evilscotsman
    1,350
    14
    The RNS-E sat nav unit is £400 second hand on ebay mate, you wont find one much cheaper than that anywhere.
  17. Niknak
    Niknak Member
    867
    And one of the best mods you can carry out imho:thumbsup:
  18. evilscotsman
    1,350
    14
    You are spot on there mate, its on my must do list too :)
  19. stevey_boy
    stevey_boy Member
    41
    is there any other bits and pieces needed to install this? and what about fitting itsself? major work?
  20. stevey_boy
    stevey_boy Member
    41
    i would be interested also
  21. quattrojames
    14,050
    575
    Me too!
  22. evilscotsman
    1,350
    14
    Nah mate its a pretty straight swap, the only thing you need is a sharkfin gps antenna, and the dvd that goes with the set too.
    (Even a 2006 dvd (not an ebay copy) can be swapped at audi for free in exchange for a 2008 one I think - might be wrong there tho.)
    The antenna means drilling thru the roof however and maybe best given to a pro to do, but not impossible if your careful to do it yourself. Use masking tape to mark the spot accurately in pencil, and to stop the drill skidding. Use the size of drill you need for the cable stub, and don't pilot it smaller then drill out, it will judder the bit and make it skip out of the hole. Dont push down, let the drill cut the hole with no pressure. Oh and of course the headliner needs dropped at least at the back to prevent drill-through and to get the cable from the antenna to the dash etc.
    ima do it myself when I get around to it :))
  23. coyote
    coyote Member
    217
    Righto... I have sent a message to Vagparts and will let you guys know the reply.
  24. Niknak
    Niknak Member
    867
    You will need to change the cage to a double din one and also the ash tray, there is plenty advise on www.navplus.us
  25. Issac Hunt
    1,162
    The new nav DVD upgrade finished last year. You dont need a sharkfin, you can fit a GPS antenna under the dash - much easier to do!
  26. coyote
    coyote Member
    217
    So who is interested now?
    coyote
  27. J7USS
    3,737
    76
    Id love to but a little pricey for me at the min, got few other bits to get first before these.
  28. jase0851
    jase0851 Member
    789
    of the top of my head thats 125 quid ish ! then shipping
  29. Nickynibbles
    Nickynibbles Damn it where's 7th gear when you need it?!
    845
    Ouch!! Makes the £30'odd quid I just paid for a set of Brabus pedals for my little Smart Roadster seem like even more of a deal!
    At that price your as well to have a look a the Samco catalogue as they do a huge range and will be cheaper. Its not like those RS4 ones have a 4-rings logo on them to make them stand out as OEM.
  30. evilscotsman
    1,350
    14
    aye, I couldnt justify over £100 for pedals.
    Isaac, cheers mate, just saw the pad type antennas the other day. I do like the sharkfin but a dummy would do then :)
  31. quattrojames
    14,050
    575
    Thanks for doing that mate, but I'm with the others right now - for £100 plus there are other mids I would sooner do. Like my upcoming cambelt change!
