Allard EGR delete kit
TDiSPORTA3 Jun 29, 2010
  1. TDiSPORTA3
    TDiSPORTA3 New Member
    Hi all, I have recently fitted the allard kit to my 2004 A3 2.0 TDi and am looking for a little help.
    First of all do you have to block the little vac pipe from the egr valve and secondly need help finding someone to help turn off the check light with vagcom.
    Recently had engine replaced as it dropped a valve and wrecked itself and since i got it back been losing power as if turbo cuts off. When you turn it off and on again the problem is cleared again. Advised to change the boost pressure sensor and have done to no avail. Any ideas???
  2. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    Yes you block off the vac pipe. Just use a small screw or bolt will do. It might help if you say where in the country you are for Vagcom help.
  3. TDiSPORTA3
    Oh yeah i'm in Glasgow. thanks devonboy. I noticed you have sensors fitted to your kit . What are they?
  4. NHN
    29,295
    1,701
    Give Khufu a shout as he's up there, I weill msn him this thread link.
  5. Khufu
    Khufu Well-Known Member
    5,704
    31
    I'm just down the road depending on which part of Glasgow your in. Can run a scan & see what comes back. Not a diesel man but will see if we can interprate results.
  6. TDiSPORTA3
    Thanks I'm in Milngavie so where would suit you?
