All of the lights!
nally
MPG the new BPH
Liverpool
Hi fourm
i have noticed that over the past few days my side repeater on the passenger side seems to be less brighter a lot less this is intermittent I have took some pics to show you all other repeaters are fine and I don't think there is a bulb error but can't tell 100% as I need to reset my oil light as it got changed 1k eirly and I don't have time to nip back the garbage to get it turned off.
Didnt wanna attemp to turn the light off I case I wipe the full service one by a incident that's due in 10k
Broken one not very bright
Front view broken
side view flicker
Brighter drivers side
Front view drivers side working
Any help would be great
There may be a crack in the strip stopping the light shining all the way through, its just 1 LED in there so if that was faulty then it would not work at all.
have a close look to see if there are any hair line cracks in it.
if not then you would need to get a new indicator part, it comes built into the strip so you would replace the whole thing.
the cost is around £27+vat from the stealers so not cheap
news not as bad as first thought thanks. So there's no bulb option ?
Reset the service light today a d there was no bulb error but when the turn sign goes on after about 5 seconds that's when it goes really weak ?
Can vagcom help?
advantage being the indicator swap is a piece of cake, perhaps time to think of led upgrades, i see no reason why you cant replace the smd's on the indicators
Can you do this by taking it apart ?
Can anyone provide information on the above ?
its now pretty much dead but non error that I find odd
