(all) Electric Windows Button on Cab only puts windows down
andrewl74 Nov 24, 2010
  1. andrewl74
    andrewl74 New Member
    23
    hi all
    the button that puts all windows up and down on my 04 Cab has now started only putting the windows down. when i try to put them back up, nothing happens.
    can put the windows up individually but the all windows doesnt work!
    help!
  2. C17LJR
    C17LJR Member VCDS Map User
    513
    either a dodgy button/switch or a issue with your CCM,
    best to get it scanned with VCDS to check for errors
  3. NHN
    29,577
    1,779
    Check with measuring blocks if the switch is recognised as in use when trying to put up, may have got some grime in the switch mate, try taking apart & cleaning as the contacts are small.
  4. swarcup
    swarcup Well-Known Member
    1,326
    40
    Do all audis have an all up buttonor method, i have 4 individual switches and a rear locking button?
  5. mja4cab
    mja4cab Member
    33
    Sounds like a faulty switch,similar thing happened to mine.
  6. quattrojames
    14,068
    585
    Just the cabs, but you can do it from your fob if it's enabled.
  7. CHRIS555
    CHRIS555 DOPE with added OCD
    1,970
    Sounds daft but do you pull it upwards quite firmly? sometimes i lift my button and have to lift it fairly hard to actually get it to raise them again???
  8. defsix
    defsix Member
    181
    Get some ESC electric switch cleaner / contact cleaner and spray inside the switch (under the lever) and work the switches. Something similar happened to mine , done the job , good as new.
  9. rjm180
    rjm180 Active Member
    581
    34
    Do you have to remove the door card to access the switch in order to clean it or is there another way. It's just happened on mine.
  10. Cabbyfan
    Cabbyfan Active Member
    840
    34
    Lift the switch as if you were using it and give it a squirt then press it up and down a load of times to work the cleaner in, just make sure you use proper electrical contact cleaner !
