All brake lights have randomly stopped working...
Mi11ar Sep 30, 2013
  1. Mi11ar
    Mi11ar Active Member
    316
    35
    Randomly on my drive back to camp on Sunday night, all 3 of my brake lights decided to stop working all at once, checked the fuse that's fine, and all the bulbs seem to be ok also, I've heard of people having a similar problem before something about a switch mechanism behind the brake pedal???
    Can anyone spread any light on this please?
  2. azman
    azman Member
    58
    same happened to mine, it was the brake switch that had packed in.
    how i love the a3 s3. easy job to change it, but i believe there are 2 variations of switch.
  3. Mi11ar
    316
    35
    Ahh yes just as I expected, I'll have to track down which switch is for my Car then :p
    Btw thanks for the pic :)
  4. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    951
    394
    The brake light switch was redesigned around 2007. The old one had a pink/violet collar and broke often - part number 1J0945511F. The redesigned part I think is black but sorry don't have the part number for that.
    If the switch has broken then your ESP light is probably on too.
    Good news is that the resigned part is much better and reliable.
    John.
  5. Mi11ar
    316
    35
    Cheers :)
    I don't have any warning lights or anything on my dash everything is showing up as fine :s
  6. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    just spray with WD-40, i did this with mine when it was sticking and been working perfectly since, it might just be stuck or biut of dodgey connection. worth just giving a spray for a cheap easy fix.
    JJ
  7. azman
    azman Member
    58
    hi, my esp light wasnt on either?
    it threw up a code for brake switch and speed controller(cruise control
  8. JohnM100
    951
    394
    Revised part is dark green - 1C0945511A.
    When mine went (twice) the ESP light came on, but if yours don't then could point to something else.
    John.
