Alignment required after installing ARB?
theronin Jul 18, 2010
  1. theronin
    theronin New Member
    14
    Just installed my H&R Anti-roll bar (ARB) and the installer had to remove the subframe to install the front bar.
    The steering wheel alignment is a little off, when the steering wheel is centered, the car is not moving straight and veering to the right. So would like to get some advice on this issue.
    Is it just a matter of doing 4-wheel alignment? Read in another forum mentioned that in addition, chassis alignment (not sure what this is) might be required????
    Thanks!
  2. Broken Byzan
    13,237
    465
    Yep, alignment will sort it. A proper place will slacken the subframe to equal out the camber and then set the tow in/out with the wheel straight
  3. theronin
    theronin New Member
    14
    Thanks for clarifying! Was a little skeptical about the chassis alignment bit. So essentially sounds like it's just doing the 4-wheel alignment.
