ali mirrors and mud flaps
S90GAV Apr 26, 2008
  1. S90GAV
    S90GAV Member
    563
    hoping someone can help me here, what the best stuff to use too clean the ali mirrors? and the other thing is i want some mud flaps for the S3, so went to audi today to get a price and according to Etka the only ones they do are for the A3 had in brackets (will not fit s3). yet i have seen s3 with them?
  2. jcs356
    jcs356 Brum brum
    2,734
    70
    Hi, if you do a search on the mudflaps you will find previous discussions. In summary, the A3 back ones 'fit' both the front and rear of the S3, although you will need to make some brackets for the top of the front mudflaps to avoid drilling into the wing. I've been running a set for 3 years no problems. Brackets can be made from some 25mm U channel from B&Q - cut into a 25mm piece, drill a hole, tap it (to cut a screw thread), fit a bolt into the tapped hole and you end up with what is like a small G clamp. Put back of clamp behind front wing lip, front of clamp in front of mudflap, tighten the screw and the mudflap is held against the wing. Easy.
  3. S90GAV
    S90GAV Member
    563
    cheers bud
  4. S90GAV
    S90GAV Member
    563
    oki cheers
  5. 1animal1
    9,978
    Anyone have any pics of an S3 with mud flaps?
  6. S90GAV
    S90GAV Member
    563
  7. jcs356
    jcs356 Brum brum
    2,734
    70
  8. 1animal1
    9,978
    cheers guys....made my mind up....think the backs are definately getting done, will decide later on the fronts...... might make cleaning the feckin thing easier
  9. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    As jcs356 said, very straightforward to do. Only did the rears on the S3 and the 'A3' Front Flaps fitted beautifully. Clean them with Megs Degreaser and APC and they shine up well.
    However on the notion that they do what they are supposed to do is....******.
