You need to remove the boot trim on the drivers side and it's underneath the so called sub, underneath the rear light cluster. Remove the boot lip trim first, this is 4 Torx T25screws, then it levers off. Then remove the 2 cargo anchors. Then the trim unclips. There's a metal clip on the boot lip, next to the rear light, then a couple along the side window. It's a very easy job.
