ALARM SETTING AUDI TT BEEP BEEP
vw754 Dec 15, 2006
  1. vw754
    vw754 vorsprung Durch Technik
    2,325
    58
    CAN ALARM ON AUDI TT 225 QUATTRO BE SET ON A BLEEP,I.E WHEN DOORS ARE LOCKED,ID LIKE IT TO BEEP ONCE LIKE MY A4 NOW DOES. HOW CAN THIS BE DONE TT QUATTRO 2000 (W)
    Is it the same procedure as a4 ?
  2. Uwe@Ross-Tech
    Uwe@Ross-Tech Member
    130
    Assuming the car has the necessary Anti-Theft system (and corresponding separate horn) installed, add 1024 to the existing coding.
    -Uwe-
  3. adigraham
    adigraham Member
    105
    what section do you go into on vag-com to add this code?
  4. Uwe@Ross-Tech
    130
    On a TT: 35-Cent. Locks -> Coding
    -Uwe-
  5. adigraham
    adigraham Member
    105
    ok what about a A£ tdi ;)
  6. Uwe@Ross-Tech
    130
    Ditto. The old A3 and TT are pretty closely related.
    -Uwe-
  7. adigraham
    adigraham Member
    105
    Thanks Uwe :)
  8. adigraham
    adigraham Member
    105
    Ok do i do this in the recoding section and if so what value do i replace as i cannot see an option to add a new one .... any help would be appreciated!
  9. Uwe@Ross-Tech
    130
    Whatever number is in the coding now, add 1024 to it.
    For example: If your existing coding was 8192, add 1024 and you'd get 9126.
    -Uwe-
  10. adigraham
    adigraham Member
    105
    right now i get it!
    thanks will try later
