alarm light flashing
stebed Jan 20, 2005
  1. stebed
    stebed Member
    30
    I have noticed that all of a sudden my indicators don't flash when I lock the car but they do when I unlock it. Any ideas??
  2. Broken Byzan
    13,237
    465
    Is the LED by the lock button flashing??
    If not it could be a door switch, making the car think a door is open
  3. a4sline
    a4sline Member
    185
    Try cleaning the switch in the bonnet lock as these are notorious for getting full of **** etc. A good clean should suffice or just check with a continuity tester if the switch is switching. i've changed a number of these over the years, comes as a complete bonnet catch.
  4. low610
    low610 Member
    125
    Evening all,
    Does anyone know where the switch is for the alarm under the bonnet. I've had a look around and cannot see it anywhere.
  5. ajmackie
    ajmackie Member
    922
    evening! it's to the right of the bonnet catch. about a foot or two away along the same panel, if it is there. mine's disconnected and is on my to do list!
  6. a4sline
    a4sline Member
    185
    B5 factory alarm switch is built into the bonnet lock mechanism. I has a wiring plug on it, just disconnect it first and see if that helps. Can't remember whether the contacts ar normally open or normally closed so either way disconnet it firs and then try bridging it.
    HTH
    Chris
  7. ajmackie
    ajmackie Member
    922
    it ain't built in on my B5.
  8. low610
    low610 Member
    125
    Evening all,
    Don't suppose anyone's got a picture of this. I've had a look and cannot find it anywhere.
    Cheers,
