Alarm Going Off On Its Own....
WOLF Aug 16, 2014
  1. WOLF
    WOLF Well-Known Member
    1,201
    270
    My avants alarm has just started randomly going off on its own when its locked,when I press open on the remote it doesn't stop it everytime and keeps beeping.the beep is coming from the rear right side behind the trim near the speaker.......Any ideas why?
    Ive checked the 2 buttons in the door pad pocket but could it be anything to do with the wife hoovering it out today?
  2. WOLF
    1,201
    270
    Also just notice my 'beep' when I press lock isn't workingo_O
  3. deano1978
    deano1978 different gear
    713
    81
    Battries have failed. U can unplug the alarm from behind the sub,if u can get to it.
    And you can check,change the battries over.
    Theres a "how to" i think, or its covered in the forum.
  4. WOLF
    1,201
    270
    Cheers mate.
    just done a quick search but appears the batteries in there are now not available anymore,i'll look into it;)
  5. moggs
    moggs Member
    75
    there is a mod you can do to it so it accepts batteries from maplins. do a search on that. mine failed a while back and I took it out to do the mod but haven't got around to it yet.
  6. Mike_B
    Mike_B Active Member
    533
    47
    Before you go pulling the thing apart, tighten the vehicle battery terminals. Worked for me.
  7. WOLF
    1,201
    270
    And as quick as it started going off randomly its now stopped,was dreading going to bed but al night there ws no 'beeping'!
    I'll keep my fingers crossed:)
  8. deano1978
    713
    81
    Think ur find this wont be the end of it im affraid. Well it was the same issues for me,mentioned above.
  9. richiepg
    richiepg New Member
    20
    Exact same thing happened to mine, i disconnected the main car battery and reconnected, havent had an issue with it since( about 2 months)
  10. WOLF
    1,201
    270
    Im thinking that mate,ill check out the siren when time allows!
  11. WOLF
    1,201
    270
    Well as suggested the alarms going off again,,from 1am this morning:mad: it kept me and two neighbours awake:sob:
    Im going to buy a second hand one and keep my fingers crossed.Does anyone know the part number for a replacement??
  12. richiepg
    richiepg New Member
    20
    The same worked for me a while back, I removed the leads, put them back on and tightened them up no probs since
  13. WOLF
    1,201
    270
    Just had to remove battery lead,not having another sleepless night:no::D
  14. richiepg
    richiepg New Member
    20
    Aye I'd do the same
  15. WOLF
    1,201
    270
    Removed the siren today and just ordered a replacement.I cut open the old siren just out of curiosity,the batteries inside are ridiculous!
    Ive never seen batteries like themo_O
    Hopefully the replacement will cure the problem:thumbs up:
  16. WOLF
    1,201
    270
    Got my replacement siren today.
    Just a thought though,can the original sirens be changed for any other sirens from the other vag cars..?
  17. WOLF
    1,201
    270
    New siren fitted all sorted.Easy enough to get to and took 20 minutes to fit.
    I cut open the old one just to have a look,printed circuit abit corroded. the batteries are like something ive never seen before....crazy!
