chippie
Hi all could do with a little help if poss, I have an intermittent fault with the passenger door, sometimes when it is shut the interior light slowly flashes on and off until the door is opened and then slammed shut again, but the dis does not show that a door is open? Also sometimes the alarm will not arm or will go off once it has armed, again once the door is opened and then slammed shut all is fine, i have scanned the car with vag com and get a couple of faults, 01367 - central locking pump run time exceeded (likely leak), 01371 - Alarm triggered by door contact switch ; Drivers side, although it is the passenger side causing the problem and also 01370 - Alarm triggered by interior monitoring, I presume that it is the micro switch at the lock thatâs faulty, can i just clean it or replace it? Or is it part of the lock. Thanks for any help
