alarm chirp on vw can it be done on audi?
rasA4 May 24, 2009
  1. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
  2. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    well i just done it to my a3 with vag .Works a treat :)
    I also done it to my old LCr , so yes it is possible :p
  3. rasA4
    3,287
    119
    how did you do it?
  4. scottie123
    1,972
    vag.com
    46 central convieniences
    long coding function 7
    Byte 8 Bit 1 - Unlocking Confirmation via Door Locks
    Byte 8 Bit 3 - Unlocking Confirmation via Remote Control
    Byte 9 Bit 1 - Locking Confirmation via Door Locks
    Byte 9 Bit 3 - Locking Confirmation via Remote Control
    Byte 10 Bit 7 - Anti-Theft-System Activation Confirmtion (Horn) This needs to remain checked
    easy peasy
    were abouts are you?
  5. scottie123
    1,972
    may of rushed into this one a bit......as you have a horn which will honk lol!
    didnt watch the vid as my flash is playing up :(
    surley it is fairly easy to instal a siren on the alarm for the chirp?
    or aint it that easy....?
  6. Wayner87
    Wayner87 Member
    43
    I would love to know if this can be done on our Audi's, the honk is so embarrassing. Only reason why I have it on is so I know when I lock the doors instead of looking at the car indicators using the remote central locking.
  7. d4mo
    d4mo Member
    100
    Honk? More like a fart isnt it Wayner?
  8. The Slug
    The Slug Active Member
    1,869
    more like a burp than a chirp haha
  9. aragorn
    18,020
    716
    its on rosstechs page under B5 A4:
    35-Central Locks: -- KWP-1281
    VAG-COM Works fine (note: pre-'97 A4's may not have this module).
    Recode locking options
    [Select]
    [35 - Cent. Locks]
    [Recode - 07]
    Enter the coding below
    [Do It!]
    Write down the existing coding for future reference.
    Add the following options to your coding number: +64 Windows up, sunroof close, and windows down with remote.
    -04 One touch unlock of all 4 doors and trunk
    -1024 Remove horn honk when arming
    +32 Auto lock/unlock of doors (Doors lock at 15 mph and unlock when key is removed)
    So if your car doesnt currently honk, then you'd add 1024 to the existing coding in that channel and save it.
    Done this on craigs S4 and it worked just fine. Its a bit of a silly noise, but its instant audiable notification that the car has locked successfully. If a door is left open or somethings not right it doesnt hoot, so you know theres something odd. Whereas just having the flashing indicators is easily missed.
    Early A4's did it by default, and it cant be disabled. For some reason on the later cars (after 97ish) they disabled it using that coding value.
  10. Wayner87
    Wayner87 Member
    43
    I think you have missed the point, if you watch the whole of the video it has 3 parts. 1 (before) where it locks with no honk and 2 (after) where it honk and 3 (after-after) where it chirps.
    I think this guy has modified his siren to make it chirp than honk. I would love to know how to do this mod but I have read some where it isnt that easy to just replace the siren.
    http://forums.vwvortex.com/zerothread?id=4002367
    http://forums.vwvortex.com/zerothread?id=2754999&page=3
    I might just get a siren, replace it and see what happens.
  11. Wayner87
    Wayner87 Member
    43
    Yeah! :happy:
  12. Wayner87
    Wayner87 Member
    43
  13. aragorn
    18,020
    716
    ah fair enough, i have no sound on the PC here at work, so i didnt actually watch the video.
  14. Broken Byzan
    13,237
    465
    TBH i am not sure that the OE alarm system gives the right kind of output to activate that. IIRC its pulsed not continuous
  15. Wayner87
    Wayner87 Member
    43
    Just ordered one off ebay on the above link, As soon as I get it, I will attempt to fit this, give feedback and also post a video.
  16. rasA4
    3,287
    119
    what does it sound like?
    and where is the alarm horn located?
  17. aragorn
    18,020
    716
    ras: i was just on about the normal audi hoot, not the chirp modification.
    I hadnt watched the video clip.
  18. rasA4
    3,287
    119
    ah ok is the alarm hoot or the car horn hoot?
  19. aragorn
    18,020
    716
    alarm horn.
    Its in the rear quarter panel on the nearside.
